Error Message " 15UT "
im sorry I thought that was just the app information.
what usb is this? it doesnt even identify as a specific model?
I just re downloaded those files.
It is called " DataStick Pro "
it seems to be a very cheap and slow usb, it sounds like we fob the issue off with a bad usb but in many cases it is the usb.
you can install just the apps package to get back up and running then run a interrogator log
The apps package is without NAV correct?
Or am I de selecting everything except for apps in the download selection?
either way but just apps will be quicker to get back up and running
Thank you. I will try this new download and if it doesnt work then I will do apps until I can grab a new USB.
I have installed the apps only. I have just one question. When I go to install maps, I use the downgrade install mode correct? Since I am now on the newest 3.4.23188?
Did you read ANY of the documentation?
Yes. Is there anything wrong with trying to make sure? Because since I have only apps downloaded I dont know if that is considered the whole system being 3.4
Reading the docs would be how you made sure and most replies you’d get here would refer you back to the doc’s or include snippets from the doc’s so basically everything you need to know has been well documented in the doc’s, so again, go read the doc’s.
