CyanLabs
(CyanLabs)
26 October 2024 12:11
1
Introduction
F13 Maps for EU has been found online and added to Syn3 Updater! thanks once again to @AuRoN
Important Notes
This release only updates the Nav, Voice Nav package no new application etc.
It is not ESN locked as per other EU map packs
Rules
Do not reply to this thread with general issues that are not specific to F13 Maps
If you notice a bug or change specific to this feature report it below
Failure to follow the above rules will result in your post either being moved (if moderators or myself are feeling generous) or deleted without prompt
To clarify, MEM_ERR’s, Missing Logos, LST_ERRS etc should not be posted here, make a new thread using this Support Link
Install Methods
Syn3 Updater
Manual Method
It’s also added to the manual method available at the below link
Cutdown Maps
It’s also added to the cut down maps at the below link
Package URLs
License:
1U5T-14G424-BN
Nav Voices:
4U5T-14G422-BAL
4U5T-14G422-BBL
4U5T-14G422-BCL
4U5T-14G422-BDL
Maps:
1U5T-14G421-BAL
1U5T-14G421-BBL
1U5T-14G421-BCL
1U5T-14G421-BDL
1U5T-14G421-BEL
1U5T-14G421-BFL
1U5T-14G421-BGL
1U5T-14G421-BHL
1U5T-14G421-BJL
SYNC 3 Common Issues and FAQ’s
Technical Information from FMods
— New Sync 3 EU F13 Maps Released —
Release Date: 2024-10-17 and 2024-10-25
Hey,
Thanks for update.
Which month or quater are this update.
Q2, Q3 or Q4 2013.
Thanks
Regards
Bostjan
SaNdMaN
(SaNdMaN)
27 October 2024 14:39
4
It’s not a file issue.
Configure a single download in syn3updater and try again.
SaNdMaN
(SaNdMaN)
27 October 2024 17:00
6
Go to the settings tab, it’s documented in the instructions → Settings Tab - CyanLabs
Once it’s set to 1, try again.
I already had 3.4.23188 so I choose to update maps only from F11 to F13. USB preparation went well, also installation in the car started fine and took around 1h. At the end I got no note to remove USB, only that first part was installed successfuly and that I should restart vehicle as soon as possible. Then soon Sync 3 rebooted, after that stated that SW upgrade was successfull and then started installation all over again - I guess I should remove USB by myself when Sync rebooted itself? Anyway, after waiting for second installation to complete I pulled out USB when noted again that first part was done.
Then I restarted vehicle, rebooted Sync 3 (normal, not master reset), but it still says maps are F11, not F13.
Any clues?
SaNdMaN
(SaNdMaN)
28 October 2024 21:09
9
This has nothing to do with the nature of this thread, you have incomplete map installation and no following the process. If you have issues create a new thread for troubleshooting.
Downloaded and installed without issue (2019 Focus). Thank you
Pawel
(Pawel)
29 October 2024 10:55
11
I already have the Sync version 3.4.23188 of the F12 map and I chose to install maps only. the update lasted about 1 hour, the system reset but I still have the F12 map version in the settings.
Any solution?
I did the update yesterday and have the same issue.
It took me more than 90 minutes to update. Did a master reset too. But still showing F12 instead F13…
coghva
(coghva)
31 October 2024 07:00
13
The same for me …installed F13 (only maps) twice …successfully updated…but in about Sync is still F12 reference…Could be an issue just for Only Download Maps?
I think I`ll try to install the entire software Software & Maps.
I’ll try that too…
If i install the same version do i have to use autoinstall or downgrade?
Thank you…
Everything good now… i installed the system and the f13 maps. Automatically it selected the downgrade mode .
Everything fine now… thanks
jonshaw
(Jon Shaw)
3 November 2024 12:04
16
68 plate Focus, Sync 3.4 build 23188 with F12 maps. All working fine.
Installed F13, the maps installed but the audio stopped working. Tried master reset, and then disconnecting the battery for an hour but still no audio. Reformatted and reinstalled 23188 and F13 again but still no audio.
Ended up reformatting and going back to F12 but the audio is still not working. The display says audio off.
Any advice appreciated.
Edit: Looks like the ACM is not communicating.
Log:
Installed files:
1U5T-14G421-BAK
1U5T-14G421-BBK
1U5T-14G421-BCK
5U5T-14G391-AT
4U5T-14G422-BAK
4U5T-14G423-AC
1U5T-14G658-AH
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance ” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2024-11-03” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>XXXXXXXXXXXXXXXXX</p:VIN>
<p:RequestRole>
d2p1:Role CONSUMER</d2p1:Role>
d2p1:RoleSource OTA</d2p1:RoleSource>
d2p1:RoleDesc SYNCGEN3</d2p1:RoleDesc>
d2p1:RoleID OTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“c100000b”/>
<d2p1:DTC DTCValue=“c184000b”/>
</p:BroadcastDTCType>
d2p1:Address 7D0</d2p1:Address>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response NU5T-14G381-AD</d2p1:Response>
d2p1:IsConfig false</d2p1:IsConfig>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
d2p1:Response 27feeaa1</d2p1:Response>
</d2p1:DID>
d2p1:Response 206f1387</d2p1:Response>
</d2p1:DID>
d2p1:Response 086a04de1002fc4640c2</d2p1:Response>
d2p1:IsConfig true</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 554b010bc00a488028b01205</d2p1:Response>
</d2p1:DID>
d2p1:Response 0000010000</d2p1:Response>
</d2p1:DID>
d2p1:Response 00001de1020102</d2p1:Response>
</d2p1:DID>
d2p1:Response 190519052653</d2p1:Response>
</d2p1:DID>
d2p1:Response 80</d2p1:Response>
</d2p1:DID>
d2p1:Response 0b0033000000005ef100005656630061</d2p1:Response>
</d2p1:DID>
d2p1:Response DS-1U5T-14G371-AE</d2p1:Response>
</d2p1:DID>
d2p1:Response 1U5T-14G380-FD</d2p1:Response>
</d2p1:DID>
d2p1:Response 3U5T-14G371-GDD</d2p1:Response>
</d2p1:DID>
d2p1:Response 1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:Response LX5G009D</d2p1:Response>
</d2p1:DID>
d2p1:Response Blank</d2p1:Response>
</d2p1:DID>
d2p1:Response 03</d2p1:Response>
</d2p1:DID>
d2p1:Response 1U5T-14G374-AE</d2p1:Response>
</d2p1:DID>
d2p1:Response </d2p1:Response>
</d2p1:DID>
d2p1:Response 0c:b2:b7:c9:e2:92</d2p1:Response>
</d2p1:DID>
d2p1:Response 0c:b2:b7:c9:e2:93</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2024-11-03T14:13:56+00:00” RAM=“1015939072” vmcuVersion=“Vector_VMCU_05.04.10”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.2G” available=“804K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“5.0G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“988M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“37G”/>
d2p1:InstallationLog/
CyanLabs
(CyanLabs)
3 November 2024 16:34
17
This has nothing to do with the update. check wiring, battery, fuses, etc
jonshaw
(Jon Shaw)
3 November 2024 17:24
18
I’m such an idiot. It was fuse 23 in the passenger fuse board. My dashcam was using it, I moved it to a better fuse (number 3) just before updating to F13 and forgot to replace it.
Thank you.
Fusee
(Fusee)
3 November 2024 22:07
19
Had 3.4.23188 already installed and used a random usb 3.0 flashdrive to update to F13 (selection of EU). 60 minuten of processing time and removed the flashdrive after Ford logo appeared. F13 is there, without having to reset to factory default. Thanks and enjoy the coffee.
PCP
(PCP)
5 November 2024 21:28
20
My compliments to the whole team. I can’t reach the F13 maps. An error appears, like the attached photo. Thank you.
Uploading: IMG_20241105_211208.jpg…
What do you mean you can’t reach them?
PCP
(PCP)
6 November 2024 15:58
23
When trying to enter the program, the error appears immediately, the same as the photo sent previously. Thank you very much.
teiksef
(teiksef)
6 November 2024 16:09
24
You can use Navigation Data Remover before installation. One of things it does is removing “/fs/rwdata/NAV/map_version” file. It seems Sync3 then recreates it with more actual content (https://www.fordescape.org/threads/how-to-change-sync3-my20-nav-us-pl-eu.123362/?post_id=1211827&nested_view=1&sortby=oldest#post-1211827 )
You can also remove it on jailbroken Sync3 by SyncMyMod/autoinstall.sh, or just leave it as is.
