Finally Successful update
After a few tries the update loaded up today. Works perfectly so far. The first few times nothing happened. If I navigated to the usb it said " no music files " available. The second time nothing happened but my usb felt like it was in a toaster. Then I reformatted the usb, removed all files from my pc and did a new download. After a few seconds it said to remove the usb but I left it in. About 40 minutes later I removed it when prompted. Tested the maps a few times using newer streets in my area and it had them. Noticed it doesn’t have any business logo’s. Was having a problem with linking my phone but now it paired up quickly.
Old SYNC Version: 3 3.0
New SYNC Version: 3 3.4
none so far
Syn3 Updater Version: 3.4
I don't have it with me. I'll get it tomorrow
Did you read the instructions… Did u do a master reset?
I had problems for the past month before doing the update. I did a reset about a month ago. Yesterday I just inserted the USB after starting the car. Took about 15 seconds for it to be recognized.
Screen gave progress until finished.
Regardless of success or failure I suggest you always do a master reset after software or map updates or both as @Hades indicated. :wink:
If I did a master reset after the update wouldn’t that erase it and go back to the OEM settings?
Thanks.
No…you retain your new update.
All the master reset does is clear any bugs especially with your new maps as occasionally they have issues without a master reset.
