Ford Explorer 2022 MY SYNC 3 update 3.4.21194
SYNC update 3.4.21194, wanted to change maps from NA to EU, when installing the test flash in APIM, the file is not generated, and when reinstalling it on the computer, this message appears.
Old SYNC Version: 3.4.21194
New SYNC Version: 3.4.22110
A message appears that you need to write about the problem
log file:///C:/Users/Dell%207510/AppData/Local/CyanLabs/Syn3Updater/Logs/Sync_W0CM3YWZ_1FM5K8HC7NGA96281.xml
First problem you’ve got is that an NA NAV APIM has 32Gb of storage and an EU APIM has 64Gb.
You’ll have to use the cut down map generator if you don’t want to replace the APIM.
