Ford Galaxy 2017 EU NAV - SYNC 2.3.17109 - Interrogator APIM Blank, safe overlay cleanup?
Hello,
I have an original 2017 Ford Galaxy with SYNC 3 v2.3.17109 and EU navigation maps F6.1. Apple CarPlay and Android Auto no longer connect; phones still charge via USB. A USB Interrogator log was generated successfully, but Syn3 Updater 2.14.2.0 reports:
“The XML file you have selected does not contain the expected output. Syn3 Updater has determined you are on 2.3.17109 and may be using overlays. Syn3 Updater is unable to determine the configuration of your APIM.”
Several APIM model / configuration values are Blank in the XML. I prepared an autoinstall for re-installing the current EU packages with the HB5T-14G387-AAB overlay removal script, based on the CyanLabs community example. I have NOT installed it.
Would you confirm whether the attached autoinstall.lst and package combination are safe for this APIM, or advise how to identify the exact hardware first? My goal is to restore CarPlay / Android Auto and if safe update to SYNC 3.0.23219, without reformatting to 3.4.
Attached: redacted Interrogator XML and autoinstall.lst. All package downloads were checksum verified.
Thank you!
Old SYNC Version: 2.3.17109
New SYNC Version: 2.3.17109
No update has been installed yet.
Syn3 Updater 2.14.2.0 shows:
APIM model and configuration values show Blank.
I have prepared the original EU packages and an overlay removal autoinstall.lst, but have NOT installed anything.
Please confirm whether this procedure is safe for my APIM. My target version is 3.0.23219.
No software update has been attempted yet, so there is no installation log.
I successfully generated a USB Interrogator XML file, but Syn3 Updater 2.14.2.0 cannot identify my APIM configuration. It reports blank APIM values and possible overlays on SYNC 2.3.17109.
I will attach the Interrogator XML and the prepared autoinstall.lst to the support topic. Please confirm the correct and safe procedure before installation.
Sync_Interrogator_redacted.xml (10.5 KB)
autoinstall.lst (491 Bytes)
Before reading into it, what does that even mean?
What’s your end goal?
Sounds more like a bad media hub, charge cable or APIM.
Do a master reset of the APIM and go into AA on the phone and remove it.
This will cause AA to go into a reconnect the next time after the phone is paired, if it doesn’t look at the above items.
Going to 3.4.x isn’t going to fix this, why haven’t you tried going to the most recent 3.0 build?
You can pull it directly from owner.ford.com
