What is your SYNC Region?
South America
What was your Old SYNC Version?
3.0.17276
What is your current SYNC Version?
3.4.21098
Do you have Navigation?
Have you read the documentation at Syn3 Updater - CyanLabs ?
Yes
Not anymore since I was able to update to 3.4, but previous to that I was having problems with the Gracenotes package.
Please paste your log output or provide the URL to your log file below
https://cyanlabs.net/syn3-updater-log/?uuid=1ebdd8c7-f7f4-6e2e-832c-0242ac120005
Please describe in detail your issue below
It’s pretty simple. I have a Ford Ka SEL 2019, and the only way I was able to update from 3.0 to 3.4 was to disable the Gracenotes package. I’d already prepared my USB when I found the solution, so I just removed the Gracenotes line from reformat.lst. Apparently this is due to my APIM having a smaller capacity than traditional ones. After that, install went trough.
My question is: am I able to install Gracenotes separatedly? Or if it didn’t install during the reformat from 3.0 to 3.4, then it won’t work at all? I guess that if storage is limited, then I won’t be able to do it.
Should I just try this? Tutorial: No Gracenotes After Sync 3.4 Installation. Manual Installation Instructions
I also read here (posted by CyanLabs) that it is possible to install a “smaller voice pack” and that by doing that, Gracenotes would fit in my storage. How can I do that? How is this “smaller voice pack” done? What does it miss?
Thanks a lot and sorry if I’m breaking any rules.
This is my first post
