What is your SYNC Region?
South America
What was your Old SYNC Version?
3.0.17276
3.4.21098
Do you have Navigation?
Yes
Not anymore since I was able to update to 3.4, but previous to that I was having problems with the Gracenotes package.
https://cyanlabs.net/syn3-updater-log/?uuid=1ebdd8c7-f7f4-6e2e-832c-0242ac120005
Itās pretty simple. I have a Ford Ka SEL 2019, and the only way I was able to update from 3.0 to 3.4 was to disable the Gracenotes package. Iād already prepared my USB when I found the solution, so I just removed the Gracenotes line from reformat.lst. Apparently this is due to my APIM having a smaller capacity than traditional ones. After that, install went trough.
My question is: am I able to install Gracenotes separatedly? Or if it didnāt install during the reformat from 3.0 to 3.4, then it wonāt work at all? I guess that if storage is limited, then I wonāt be able to do it.
Should I just try this? Tutorial: No Gracenotes After Sync 3.4 Installation. Manual Installation Instructions
I also read here (posted by CyanLabs) that it is possible to install a āsmaller voice packā and that by doing that, Gracenotes would fit in my storage. How can I do that? How is this āsmaller voice packā done? What does it miss?
Thanks a lot and sorry if Iām breaking any rules.
This is my first post ![]()
Just did the report, this is what it says:
