FordSyncDownloader is a Windows application created to make the upgrade process of Ford Sync as simple as possible.
not work with my PC I install it and put my version nothing showed up ??? and it showing me message when I open the application
Do you have dot net installed?
Please try new version
great work. the last version it's working. thank you
updating hanged after repartitioning emmc, states ERROR In: Package_ERRO3 . it stopped there
HELP!
same here
use the other way to update https://cyanlabs.net/tutori... the 2nd part in another USB then insert., this part follow it then use the download , now i have the sync 3.4 https://uploads.disquscdn.c....
while this works i need to know peoples issues as these links will be removed soon due to potential legal issues and storage constraints
i assume you got the error but with no file name like this?
Error in : PKG_ERR03
i believe this was due to a small line issue in the reformat.lst please could you try the latest version released earlier today, it should autoupdate.
actually it was due to a typo of APP instead of APPS in the reformat.lst, i have personally tested the server side fix and all is good now.
thanks, i just opened reformat in notepad and added S in APP so APPS.
I assume it worked?
have not tried it again
Uptaded my sync3 from ver3.019(dont_remember_the_number) to this new one and everything works fine! Thanks!
One last question: can i place the nav of android auto in the small screen, like the example image ?
depends on the car
i mean did it work when you changed the APP to APPS
Its a fiesta mk7
i don't know which cars do and don't i just know it depends on the car.
Hi,
I am a little confused now.
Downloaded the application. Everything went ok.
Tha app prepared a 32 Gb USB.
But according to the instructions I need 2 usb ememory sticks?
Or is 1 sufficient.
My USB looks like this:
you only need 1
The program does it all for you on 1 USB
