Wrote successfully but nothing yet, I’ll drive around some tonight and tomorrow.
Getting Flank Guard and the little car on the right while backing up to display on a sync 3 retrofit
Test the parking assist features also. What are your APIM settings for the APA? They should be set for front and rear for NA.
Try one of these…
7D0-04-02: xx**-xx
02=Rear/Front PDC (8 Sensors)
03=Rear/Front PDC SAPP (NA HMI)
Finally got to this, thank you so much for not giving up!! I tried 02 (car is currently on 03) and nothing seemed to change.
You could try one of the other values just to see if there is a response, but it looks like there is something else causing the issue, like the PAM is not capable or something like that. The asbuilts look like they should work.
Messed around some more and drove around and yeah nothing…I think the smoking gun is that someone said in the 2GFusions thread that no setting would make it show up on Sync 2 either
I guess the only way to get it to work is to get an auto park BCM
Thanks for all your work again @F150Chief !!!
