GPS not working and clock not correct on Sync 3 retrofit unit.
I have a recently purchased 2015 F250 with a retrofitted Sync 3 APIM (older than 2020) and K series screen (newer than 2020). This Sync3 system was in the truck when I bought it so I don’t have history on the retrofit. The GPS and Clock Sync are both not working correctly. I’ve attempted to manually set the clock, but it will then revert back within a few seconds to a random time. I’ve tried toggling/untoggling the timezone settings. There is a GPS antenna connected via blue jack and an aftermarket antenna is taped underneath the dash a few inches behind the APIM location. When I first bought the truck the GPS was showing a location in Florida, which is where it was purchased from, but never updated to the new location (Idaho). I assume since the GPS was showing Florida, at some point it would have been working correctly. After update the GPS shows current location as the Ford plant in Dearborn Michigan. In attempt to fix the issue, yesterday I updated from sync 3.4.23088 to 3.4.23188, but that didn’t correct anything. I also did a master reset after the update. The update was successful with no issues. Keep in mind the GPS & Clock problems were already there prior to my update yesterday so this isn’t related to an update issue. When I checked the diag menu a couple weeks ago zero satellites were showing up, but I haven’t checked it after the update as I assume it hasn’t changed. No errors show within DTC scans. I’ll upload pictures of the settings for reference. Thanks
Old SYNC Version: 3.4.23088
GPS disabled on navigation screen (red circle with line thorugh it)
Syn3 Updater Version: Syn3 Updater 3.0
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2014-01-01" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN></p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
<d2p1:Response>345535542d3134473432312d434148000000000000000000345535542d3134473432312d434248000000000000000000345535542d3134473432312d434348000000000000000000345535542d3134473432312d434448000000000000000000345535542d3134473432312d434548000000000000000000345535542d3134473432312d434648000000000000000000345535542d3134473432312d434748000000000000000000345535542d3134473432312d434a48000000000000000000345535542d3134473432312d434848000000000000000000355535542d3134473339312d435300000000000000000000345535542d3134473432322d434150000000000000000000345535542d3134473432322d434250000000000000000000345535542d3134473432322d434350000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>f2069179</d2p1:Response>
</d2p1:DID>
<d2p1:Response>75465ee5</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a2219001e60201420002</d2p1:Response>
</d2p1:DID>
<d2p1:Response>555301030002010000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0100010300</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01030500000001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1aae1a403e80</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>2d003a0000000003be00005656a500cf</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HP5T-14G380-BA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HP5T-14G371-CCA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>VW1GE1GN</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>HB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>38:d2:69:37:e2:9e</d2p1:Response>
</d2p1:DID>
<d2p1:Response>38:d2:69:37:e2:9f</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2014-01-01T15:24:53+00:00" RAM="1045508096" vmcuVersion="Vector_VMCU_05.02.08">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.6G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.6G" available="13M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="10M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.0G" available="3.0M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="7.4M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.9G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="6.4M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.7G" available="16M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="23M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="992M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="3.4G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>MIIEtAYJKoZIhvcNAQcDoIIEpTCCBKECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBAHAo8oHLzSP/cv1pLqJwlnKlqoa1WQskhfIBhsa6LT2H77Le4jCfxyUHKlEMMOWrspSUnCghv6b4IZiagGvRi+ssVBltHoZm/Rrvxf5sD1J//iY8YlqxrPLWKZI2ZvAtu9BGemxBZValOtqtgD3X+isYRJAeYbfc9+E/d9N+VXh+rU127TFvaBzxxkBmawb1uI53B/9c0DcXpvDmTLHqck8Ue0h7REGgq21BFfBT9pQhrjUB2P/cvQeXS1PNGwm9G5GJUn40kwwLzS48W3WFwD76ywMT4t6KviMmxIHhBnOvvMzWAKueyiwRbSoHyblxcf4dF4gvvMW59a6+Tj+D8agwggLeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBBkSzBM1JFgNUNy6L0mxgRhgIICsKuwCGh6wkZJUsmOBaco1Y9OSei2+xuBt2xqi508bYA7cqPpflQ7/1t7OnXvidlEvUmPvKnloTW7uKAUtxXmBsqRvAOLVzAa0qOI/hZdAEVZATdtRDsXz30R56vnaAFLXqvUspWHpHQWjJPyz4jjnvnGIJyxdQwkijlUTl7kJGpkZPbhNyKisPNY0pxH8eRuRq0hO2WkVuwQ4Q9BECaSViaxVQM1480xjf5txLZKDf2MYhDzr5j95WznI9WUrPvERge5eFE6IGgDQ4eGkbV7b4GXynoG9BZm3z8bL6D1VxhDydE8jYDdh1ldxoPCVlTsKgaYgagg0c3MGuWO36PBMYlBdZNmQvLK+NzHuxuSHDGZw4VSITEUOx3owB0cbc0/Ve7kiJSfiz0t9NTNVWw5Zjvth3zkxgy6QiBXhZ4xeGA/CK+pl60ul98Wa/ky2I0SBaayu+MdQU4LhV0+YDvzlUP29s1fyYVLnMPuxuJy+xAyN/vExy2HY+hJtBn7mAqztaC1N4eGDlVC+axoCaQPawpyFp2Nd1uxporwffWQW5tTT4KFUMeRuZofQRqOUz0Kmt81zFLuIa00JGoMj38Y6GMvLZhUl9qpypVr5YxB3OKh4DXqmdNdnrPocOoohKQvhnpNlUI5KFl3uQxCt6WNFU9Hxxe4W6dInlN9Tb5z4iSIbD6pVbb+6vSaOxLfn2kSMOew8VCaYKZFjCbKzN8HgziXnS0Qugq6ZqBuXEiL3g0B2XQZKoqglq7PoOanp1iOMlB76ehCntYpJYUjas0pPzuZJHizhkGzx7spxsyR1w6feAMrEKkHP5jBFefxXhovSXaFKrdzyHU2yPu5JI/5AVmMDD0+6O+sKUr5spSY9jPZy4BXAn3V+dBqBj0e81eSy0/OvhOUi7QOGXHrSYzuG7c=</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
I will wait for others to chime in but I am 99.9% sure thats a Chinese APIM clone.
I will not say how I know becuse they use Cyanlabs also and are on here. We don’t need them making them anymore realistic. One thing for sure is the double USB ports. Those are on H series APIM’s and not a J series like your sticker shows.
Based on the pic’s, you have a bad antenna or APIM issues. Many of these will crop up when you go to the newer Sync versions.
Ok thanks for the input. I do agree from our previous thread that the APIM is not Ford oem.
Installed on the APIM:
NU5T-14G381-AD
5U5T-14G391-CS
4U5T-14G423-CC
4U5T-14G421-CAH
4U5T-14G421-CBH
4U5T-14G421-CCH
4U5T-14G421-CDH
4U5T-14G421-CEH
4U5T-14G421-CFH
4U5T-14G421-CGH
4U5T-14G421-CJH
4U5T-14G421-CHH
4U5T-14G422-CAP
4U5T-14G422-CBP
4U5T-14G422-CCP
4U5T-14G423-CC
Storage looks normal…
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“992M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“25G” available=“3.4G”/>
The APIM is:
d2p1:ResponseHP5T-14G371-CCA</d2p1:Response>
This is an older APIM, an H series, not a J series. Dead giveaway is the metal GPS connector and the 2 USB ports. It is equipped with Pre-MY18.5 firmware.
The firmware is:
d2p1:ResponseHB5T-14G375-CA</d2p1:Response>
d2p1:ResponseHB5T-14G374-CA</d2p1:Response>
HB5T-14G375-CA is the Strategy file for ROW. Might be why the GPS satellite is not working.
Reflashing the APIM firmware might make the GPS work, unknown if it is a software or hardware issue based on the info.
Thanks, is there another thread that references where to download the correct firmware from and what the flash process is? I recall reading in the community that firmware is done via forscan, is that correct?
There is a guide that has this information. You will need a paid version of FORScan and a good USB OBD adapter for the firmware.
Thanks F150Chief - Very good post that you created and sent through for referencing APIM generation types as helps me understand things better.
I’ve seen in other threads that you provided a “this is where you are” chart and a “you can safely go to this” chart. I think that would be helpful for me in this case to make sure I’m selecting the correct values when doing dropdowns for firmware versions within the forscan current and future columns.
While reviewing the info I wanted to double check what I think might have been a typo to make sure I’m on the correct path. Since my APIM is a knockoff unit with the incorrect part number sticker, based on the double USB ports alone I’m assuming it would be the first Pre-MY18.5 unit mentioned in your document:
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H thru Early J Series)(Originally Found On 2017/Early 2018 Units That Ship with 2 USB Ports on Back)
Based on that assumption being correct…
  1. You stated the ‘Strategy (F188)’ file was incorrect as being related to ROW. Within the interrogator log my F188 Strategy file is HB5T-14G374-CA. According to the information in your knowledgebase article which references North America region (directly below) it shows that the strategy file should be: Strategy (F188): HB5T-14G374-CA. That would be the same as I already have listed in my interrogator log so I’m assuming that was a typo and no change would be needed for the Strategy firmware, but correct me if I’m assuming wrong.
PRE-MY18.5:
Calibration (F124): HB5T-14G375-DA or HB5T-14G375-FA (NAV) / HB5T-14G375-CA (NON-NAV)
ECU Configuration/Illumination Strategy (F16B): HB5T-14G379-BA
  1. What I do see as being an issue with mine, however, is the Calibration (f124) file. My log shows my current Calibration file as HB5T-14G375-CA. Comparing that to your region list (directly below) it appears that my Calibration file is Non-NAV + ROW region (line item three below). Would the appropriate thought be that my Calibration file needs to be changed from HB5T-14G375-CA to HB5T-14G375-'D’A in order to line up with your four line down “xxxx-14G375-D*.vbf 32GB NA with NAV (Telenav)”?
Calibration File Region:
xxxx-14G375-A*.vbf 8GB / 16GB EU without NAV
xxxx-14G375-B*.vbf 8GB / 16GB NA without NAV
xxxx-14G375-C*.vbf 8GB / 16GB ROW without NAV
xxxx-14G375-E*.vbf 32GB CHINA with NAV (Telenav)
xxxx-14G375-F*.vbf 32GB ANY region with NAV (US Export vehicles) (Telenav)
xxxx-14G375-G*.vbf 32GB ROW with NAV (NNG)
xxxx-14G375-H*.vbf 64GB EU with NAV (Telenav)
xxxx-14G375-J*.vbf 32GB TURKEY with NAV (Telenav)
xxxx-14G375-K*.vbf 32GB UAE with NAV (NNG)
  1. My follow up question to mine having Non-Nav ROW firmware would be what happens if my unit doesn’t actually have Nav abilities and I put Nav firmware on it? I read in one of your links that Forscan uses an algorithm to only list hardware compatible firmware so maybe this isn’t an issue for me anyway. Is it for certain a Nav unit due to having a GPS antenna connector on the back so my Non-Nav vs Nav concern isn’t relevant?
It’s more than that I am just not going to list them all.
That’s fine, I want to be respectful of your time for sure. More so just trying to be diligent on my end to make sure I know exactly what I have so I don’t try to flash firmware to an incompatible version and brick the unit. As long as 150Chief (no rush) and provide me with my current vs future safe firmware update comparison then I should be safe.
I also bought one of the recommended gps antennas to test with later this week as well.
The HP5T-14G371-CCA is a NAV unit.
You can safely flash the firmware to:
3.2/3.3 APIM NAV & NON-NAV Unit Firmware (Production Release, 2018.5, Late J thru K Series)
Strategy (F188): 1U5T-14G374-DA (6/27/2018)
Calibration (F124): 1U5T-14G375-DA (NAV) / 1U5T-14G375-CA (NON-NAV)
ECU Configuration/Illumination Strategy (F16B): JB5T-14G379-BA (6/7/2018)
Thank you both for the quick responses. I will buy a forscan license and give it a go later this week.
One other question: Do I need to be concerned with the other firmware version dropdown fields that aren’t listed in your response (Calibration Level, Hardware Number, Image )? Would i just select whatever the current version is in the “To Program” column or would I just leave them blank? Or other?
When you program firmware or software you should program these in the sets or packages as released by the manufacturer. So in this case, program the other files as listed above. For NA APIM’s, program all of these at once.
I was able to test with a recommended aftermarket GPS antenna and it worked correctly, but wasn’t a great signal. With that said I think I’ll leave the firmware at current level even though its wrong region. I believe I’ll go the route of converting to an OEM roof mount puck antenna moving forward. Can one of you let me know the alphanumerical value/location within forscan I need to change to go from underdash GPS antenna to roof mount antenna? I think it was something to do with power settings or similar. Thanks.
7D0-03-01
Great thanks. I’d say this ticket can now be closed. I may update firmware down the road, but would open a new ticket if needed at that time. Thank you all for the assistance with my recent troubleshooting!
