Hi everyone,
I have recently retrofitted my Ford Focus MK3 2015 hatchback from SYNC 1 to SYNC 3. After programming with FORScan, I am getting a persistent DTC in the APIM module:
Code: U2101 - Control Module Configuration Incompatible
Status (-0B):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
The screen and basic functions seem to work, but this configuration error remains. I suspect there is a mismatch in my APIM As-Built blocks or a conflict with the central configuration (BCM).
I have attached my APIM As-Built configuration file (.abt) and the log below. Could anyone please help me look into the As-Built code to see what is causing this incompatibility?
Thank you in advance!
VIN: RL05DF6AMFJR09225
Mô hình APIM: 4U5T-14G371-FDE
Loại APIM: Navigation
Kích thước APIM: 32GB
Dung lượng trống APIM: 19G
Phiên bản 3.4.26057 (NU5T-14G381-AE)
5/26/2026 3:26:32 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 648K / 1.3G
/fs/Nuance/ = 7.0M / 1.7G
/fs/Nuance/grace = 63M / 1.4G
/fs/rwdata/ = 971M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 19G / 25G
Installed Packages
1U5T-14G658-AH
4U5T-14G421-FEL
4U5T-14G423-FC
5U5T-14G391-FT
4U5T-14G424-FEL
APIM AsBuilt
DE00: 0B68659A10040C190004
DE01: 564D0B060003082000000000
DE02: 024D390000
DE03: 01000000000005
DE04: 17FE17FE3185
DE05: 80
DE06: 16013300000000167600005656880081
SYNC Region: ROW
Old SYNC Version: 3.4.19200
New SYNC Version: 3.4.26057
APIM Error Code: U2101 - Control Module Configuration Incompatible
Version: 3.4.19200
Region: ROW
Install Mode: Tự động dò (autoinstall)
My20 Protection Enabled: Cho phép
Model: KIOXIA TransMemory USB Device
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.23188 ROW
Item2 = VOICE - 5U5T-14G391-FT_1660787787000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-FT_1660787787000.TAR.GZ
Item3 = GRACENOTES - 4U5T-14G423-FC_1615431949000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G423-FC_1615431949000.TAR.GZ
Item4 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item5 = APPS - NU5T-14G381-AE_1778770590000.TAR.GZ
Open5 = SyncMyRide\NU5T-14G381-AE_1778770590000.TAR.GZ
FILES (5)
5U5T-14G391-FT_1660787787000.TAR.GZ (1.4GB)
NU5T-14G381-AE_1778770590000.TAR.GZ (869.9MB)
[5/23/2026 9:31:43 AM] Selected Region: ROW - Release: Sync 3.4.23188 - Map Version: Giữ bản đồ hiện có
[5/23/2026 9:31:43 AM] Install Mode: Tự động dò (autoinstall) Forced: False
[5/23/2026 9:31:43 AM] MY20 Protection: Cho phép
[5/23/2026 9:31:43 AM] Formatting USB drive
[5/23/2026 9:31:43 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[5/23/2026 9:31:52 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/23/2026 9:31:52 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[5/23/2026 9:31:52 AM] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[5/23/2026 9:31:56 AM] Validated: 5U5T-14G391-FT_1660787787000.TAR.GZ (Skipping Download)
[5/23/2026 9:31:56 AM] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[5/23/2026 9:31:59 AM] Validated: 4U5T-14G423-FC_1615431949000.TAR.GZ (Skipping Download)
[5/23/2026 9:31:59 AM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[5/23/2026 9:31:59 AM] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[5/23/2026 9:31:59 AM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[5/23/2026 9:32:02 AM] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[5/23/2026 9:32:02 AM] Preparing USB drive
[5/23/2026 9:32:02 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/23/2026 9:32:02 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/23/2026 9:32:02 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/23/2026 9:32:02 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/23/2026 9:32:02 AM] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[5/23/2026 9:32:02 AM] Copying: 5U5T-14G391-FT_1660787787000.TAR.GZ
[5/23/2026 9:34:57 AM] Validating: 5U5T-14G391-FT_1660787787000.TAR.GZ
[5/23/2026 9:35:01 AM] Copied: 5U5T-14G391-FT_1660787787000.TAR.GZ
[5/23/2026 9:35:01 AM] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[5/23/2026 9:35:01 AM] Copying: 4U5T-14G423-FC_1615431949000.TAR.GZ
[5/23/2026 9:36:57 AM] Validating: 4U5T-14G423-FC_1615431949000.TAR.GZ
[5/23/2026 9:37:01 AM] Copied: 4U5T-14G423-FC_1615431949000.TAR.GZ
[5/23/2026 9:37:01 AM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[5/23/2026 9:37:01 AM] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[5/23/2026 9:37:07 AM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[5/23/2026 9:37:07 AM] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[5/23/2026 9:37:07 AM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[5/23/2026 9:37:07 AM] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[5/23/2026 9:38:58 AM] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[5/23/2026 9:39:03 AM] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[5/23/2026 9:39:03 AM] Generating Autoinstall.lst
[5/23/2026 9:39:03 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
