HELP Sync 3.0 to 3.4
I have downloaded the relevant information to the USB stcik but when i put it in the usb in the van I get a red screen saying error
Old SYNC Version: 3.0.23219
red screen
www.
Do you realize you just created a thread that says “it does not work” witout any relevant information?.
There is only1 folder Syn3updater
Ok
SaNdMaN thankyou for your reply, Yes I do realise that the information is limited but that is literally all i have got to give
No, you don’t.
At least post that…
Also, do you have a picture of the red screen?. If so, post it.
Or, tell us at which time does it fail, and the exact text it fails with.
I am just trying the download again so once that is done i will post the log up then go and take a picture of the red scrren
There’s no need for that, syn3updater saves all the logs. You said you read the documentation:
So from Logs Tab - CyanLabs you can see Syn3updater saves all the logs, so there’s no need to recreate anything, I need to see the log for the USB you already used. It’s also already on the USB you created.
If you can recreate the error and share a picture of the red screen, that’s even better. But the log will tell relevant information.
Also, are you sure your unit has NAV?.
Version: 3.4.23188
Mode: Directory
Path: C:\Users\Admin\OneDrive\Desktop\FORD IDS 130\
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.23188 EU
Item2 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item3 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item4 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item5 = APPS - NU5T-14G381-AD_1689364279000.TAR.GZ
Open5 = SyncMyRide\NU5T-14G381-AD_1689364279000.TAR.GZ
FILES (5)
[20/03/2026 21:13:54] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[20/03/2026 21:13:54] Install Mode: Auto-Detect (autoinstall) Forced: False
[20/03/2026 21:13:54] MY20 Protection: Auto-Detect
[20/03/2026 21:13:54] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:13:54] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:13:54] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:13:54] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:13:54] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:13:54] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:17:11] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:17:19] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:17:19] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:17:19] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:18:29] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:18:33] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:18:33] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:18:33] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:18:40] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:18:40] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:18:40] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:18:40] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:20:17] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:20:21] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:20:21] Preparing selected directory (No USB Drive Selected)
[20/03/2026 21:20:21] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:20:21] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:20:21] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:20:21] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[20/03/2026 21:20:21] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:20:21] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:20:35] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:20:43] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[20/03/2026 21:20:43] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:20:43] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:20:49] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:20:54] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[20/03/2026 21:20:54] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:20:54] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:20:54] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:20:54] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[20/03/2026 21:20:54] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:20:54] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:21:02] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:21:07] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[20/03/2026 21:21:07] Generating Autoinstall.lst
[20/03/2026 21:21:07] ALL FILES DOWNLOADED AND COPIED TO THE SELECTED FOLDER SUCCESSFULLY!
Thanks.
I’ve some issue with that:
That contradicts what you said before.
Does the unit have nav?
This is wrong, this is not an USB to go from 3.0 to 3.4. What are you even doing?.
Do not do that, let syn3update create the USB directly.
Again, you are making this harder than it’s.
The template and myself asked for very basic information, you are not providing any that, in fact you are giving contradicting information.
So take your time and read the Basic Usage - CyanLabs guide… Recreate the USB accordingly (set 3.0 as your current build) and try again.
If that fails, provide what’s already been asked for.
