Hello to all! I have a 2015 Ford F150 with a donor unit from a 2017 Ford Fusion. It is currently at 3.3.19025, and I would like to upgrade it to 3.4 (fairly certain it’s possible based on other forum posts.) But for whatever reason, whether it’s removing GraceNote, Voice, different USB devices, and different versions of 3.4, I cannot get my APID to update.I even tried downgrading to 3.0 thinking I could go to 3.4, but it hasn’t worked. I’m all ears for opinions. Thanks in advance!
Travis
Navigation Variant: No
Old SYNC Version: 3.3.19025
New SYNC Version: 3.3.19025
MEM_ERR03 was the last one I got
I’d just like to upgrade to a 3.4 build…the APIM came programmed with my VIN. They took the parameters and loaded it for my truck. I will see what I can do first thing in the morning. Thanks in advance for all your help!
Well, for the sake of not ruining what I have, I may just pause…I thought it’d be pretty to navigate this, but after reading through, it’s more in-depth than I thought. I tried to run an update to the most up-to-date 3.4 build with the app only (no voice or GraceNotes) and am still getting the MEM_ERR03 error.
It runs the program and displays message on top of screen Updating…I set the current version, but when I go back to read the log, nothing is there. I have tried it with several different USB drives.
I’m sure if I removed the GraceNotes from the current 3.3.19052 build that’s installed, it’d go fine. But I cannot find the download for that (GB5T-14G386-SC_85041.tar.gz)
What version of the APIM Interrogator Utility is it using? Look on the disk in the SyncMyRide folder, it will be -AD or -AC?
GB5T-14G386-SC_85041.tar.gz can be downloaded from the Software Database - CyanLabs
