Help with SYNC 3.4 update on 2017 F-150 Raptor
Hey everyone, I’m trying to update my 2017 F-150 Raptor with factory nav from SYNC 2.2.16280 to 3.4.23188 with NA 2.25 maps.
I ran the Interrogator first, but Syn3 Updater says it can’t determine my APIM configuration and mentions that 2.2.16280 may be using overlays.
Everything currently works fine and I haven’t run the reformat yet. I just want to make sure I don’t brick the APIM. Am I safe to go straight to 3.4, or is there something I need to update first because of the GB5T-14G374-CB firmware?
Old SYNC Version: 2.2.16280
The XML file you have selected does not contain the expected output
Syn3 Updater has determined you are on 2.2.16280 and may be using overlays
Syn3 Updater is unable to determine the configuration of your APIM
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2026-10-25" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>1FTFW1RG8HFB66466</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
  <d2p1:ECUAcronym name="APIM">
    <d2p1:State>
          <d2p1:Response>HN1T-14G381-LG</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>484e31542d3134473339312d434300000000000000000000484235542d3134473432312d434400000000000000000000484e31542d3134473432332d434100000000000000000000484235542d3134473432342d434400000000000000000000484e31542d3134473432322d434100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>63bcea46</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>be72c46b</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>aa2a05030402ab02148a</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>55530503f402029000000005</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>0000010300</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>010014002d0001</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>1a681a6838a4</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>47003300000000029a00005656ae00c8</d2p1:Response>
        </d2p1:DID>
        <d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
          <d2p1:Response>DemoAudioProfile</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>HP5T-14G380-BA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>HP5T-14G371-CCA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>GB5T-14G375-CA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>VW2D9R5J</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
        </d2p1:DID>
          <d2p1:Response>GB5T-14G374-CB</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>98:5d:ad:82:4f:8f</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
      </d2p1:Gateway>
    </d2p1:State>
  </d2p1:ECUAcronym>
  <d2p1:ODLNetwork d2p1:NetworkDataRate="500" d2p1:NetworkName="HS1" d2p1:NetworkProtocol="CAN" d2p1:DLCName="SAE J1962" d2p1:Pins="6,14"/>
  <d2p1:AdditionalAttributes logGeneratedDateTime="2026-10-25T23:22:17+00:00" RAM="1440284672" vmcuVersion="Vector_VMCU_02.02.20">
    <d2p1:PartitionHealth type="/dev/hd0t180" total="9302595584" available="54710240"/>
    <d2p1:PartitionHealth type="/dev/hd0t181" total="578113536" available="2097120"/>
    <d2p1:PartitionHealth type="/dev/hd0t177" total="136776704" available="2097152"/>
    <d2p1:InstallationLog/>
    <d2p1:SyncData>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</d2p1:SyncData>
  </d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Hi.
Manually install 2.2.17011 then try again the interrogator.
Read 2016 Mustang Sync3 1.0 updated to 3.0 and no Apple Carplay! - #10 by SaNdMaN as reference.
