Hey guys, Im having a problem with the fix for the rwdata full problem.
Im at the end of this guide APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates and have a question about the script.
I get that I create a new txt file, name it autoinstall.sh and enter this as the text
#!/bin/bash
POPUP=/tmp/popup.txt
function displayMessage {
echo “${1}” >> /fs/usb0/SyncMyMod/install.log
echo “${1}” >> $POPUP
/fs/rwdata/dev/utserviceutility popup $POPUP
#echo “${1}”
displayMessage “Deleting /fs/fordlogs”
rm -r /fs/rwdata/fordlogs/*
displayMessage “Deleting /fs/slogs”
rm -r /fs/rwdata/slogs/*
displayMessage “Deleting /fs/dumps”
rm -r /fs/rwdata/dumps/*
displayMessage “Script complete.”
But how do I run that script? Do i use forscan or syn3… Do i just put it in the syncmyride folder and plug in a usb?
thanks for the help
CyanLabs
(CyanLabs)
2
You need to jailbreak your APIM, follow the instructions on fmods.
/Moved (this is not a guide)
sorry… said i was at the end of the guide meaning I have jailbroken already. but how do i run that last script?
SaNdMaN
(SaNdMaN)
4
Have you read the last part of the tutorial?
CyanLabs
(CyanLabs)
5
Id assume the script file goes in syncmymod folder and then you insert the usb in to the car.
CyanLabs
(CyanLabs)
7
As of now, you can use the just released ford rwdata cleaner, now integrated in to syn3updater
