I recently traded my vehicle for a 2016 Ford Flex. The car came with the Sync3 navigation system and everything on it was V1.0. After plenty of headaches and googling, I was able to update the system to 2.216280.
Prior to using the cyanlabs tool, I tried using Ford’s updater again, but to no avail after 5 hours of driving around with the updater USB inserted.
Just trying to justify my stupidity here, but I was super fed up and on the massive warning screen that tells you that you’re going to brick your system if it’s version MY20, I just assumed that it wasn’t due to how old the vehicle is and the fact that it came equipped with V1.0 software.
Anyways, I downloaded the correct updater version and everything from the Cyanlabs tool, and then inserted the USB into my car, turned it on, got a black screen, and it’s stayed that way since.
I tried the soft reset (Power+Next song) and it did nothing. I tried the interrogator tool, but it didn’t receive any info. When I plug my phone into the USB ports, it does charge, but it doesn’t enter android auto (which was working prior to trying to update from 2.2).
It seems like this is a common issue, so I’m just wondering if someone can give me the quick and dirty of what exactly I need to replace. I have a forscan tool being delivered this evening, if that’s going to be required to diagnose the issue as well.
Navigation Variant: Yes
Old SYNC Version: 2.2.16280
New SYNC Version: 3.4.20220
Black screen
Syn3 Updater Version: Newest
Version: 2.2.16280
VOICE=5U5T-14G391-CR_1644007976000.TAR.GZ
; CyanLabs Syn3Updater 2.11.4.0 Stable - reformat Mode - Sync 3.4.22110 NA
FILES (17)
5U5T-14G391-CR_1644007976000.TAR.GZ (385.5MB)
[2022-08-22 11:02:28 AM] Selected Region: NA - Release: Sync 3.4.22110 - Map Version: 2.21 (2021) - NA
[2022-08-22 11:02:28 AM] Install Mode: Auto-Detect (reformat) Forced: False
[2022-08-22 11:02:28 AM] MY20 Protection: Auto-Detect
[2022-08-22 11:02:28 AM] Formatting USB drive
[2022-08-22 11:02:28 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2022-08-22 11:03:11 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2022-08-22 11:03:11 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2022-08-22 11:03:11 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2022-08-22 11:03:13 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:13 AM] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[2022-08-22 11:03:15 AM] Validated: 5U5T-14G381-EZ_1652218180000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:15 AM] Checking Existing File: 5U5T-14G391-CR_1644007976000.TAR.GZ
[2022-08-22 11:03:16 AM] Validated: 5U5T-14G391-CR_1644007976000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:16 AM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2022-08-22 11:03:19 AM] Validated: 4U5T-14G421-CAE_1644006917000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:19 AM] Checking Existing File: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[2022-08-22 11:03:20 AM] Validated: 4U5T-14G422-CCK_1644009966000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:20 AM] Checking Existing File: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[2022-08-22 11:03:23 AM] Validated: 4U5T-14G422-CBK_1644010207000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:23 AM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2022-08-22 11:03:26 AM] Validated: 4U5T-14G422-CAK_1644007869000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:26 AM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2022-08-22 11:03:29 AM] Validated: 4U5T-14G421-CHE_1644007810000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:29 AM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2022-08-22 11:03:32 AM] Validated: 4U5T-14G421-CGE_1644007746000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:32 AM] Checking Existing File: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[2022-08-22 11:03:34 AM] Validated: 4U5T-14G421-CJE_1644007404000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:34 AM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2022-08-22 11:03:37 AM] Validated: 4U5T-14G421-CFE_1644007219000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:37 AM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2022-08-22 11:03:40 AM] Validated: 4U5T-14G421-CEE_1644007167000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:40 AM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2022-08-22 11:03:43 AM] Validated: 4U5T-14G421-CDE_1644007104000.TAR.GZ (Skipping Download)
[2022-08-22 11:03:43 AM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:03:46 AM] Validate: 4U5T-14G421-CCE_1644007033000.TAR.GZ (Failed!, Downloading)
[2022-08-22 11:03:46 AM] Downloading: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:03:57 AM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:04:00 AM] Downloaded: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:04:00 AM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:04:00 AM] Downloading: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:04:12 AM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:04:15 AM] Downloaded: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:04:15 AM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:04:15 AM] Downloading: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:04:16 AM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:04:16 AM] Downloaded: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:04:16 AM] Preparing USB drive
[2022-08-22 11:04:16 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2022-08-22 11:04:16 AM] Copying: 1u5t-14g386-cb.tar.gz
[2022-08-22 11:04:16 AM] Validating: 1u5t-14g386-cb.tar.gz
[2022-08-22 11:04:16 AM] Copied: 1u5t-14g386-cb.tar.gz
[2022-08-22 11:04:16 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2022-08-22 11:04:16 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2022-08-22 11:04:27 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2022-08-22 11:04:31 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2022-08-22 11:04:31 AM] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[2022-08-22 11:04:31 AM] Copying: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[2022-08-22 11:04:49 AM] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[2022-08-22 11:04:56 AM] Copied: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[2022-08-22 11:04:56 AM] Checking Existing File: 5U5T-14G391-CR_1644007976000.TAR.GZ
[2022-08-22 11:04:56 AM] Copying: 5U5T-14G391-CR_1644007976000.TAR.GZ
[2022-08-22 11:05:09 AM] Validating: 5U5T-14G391-CR_1644007976000.TAR.GZ
[2022-08-22 11:05:12 AM] Copied: 5U5T-14G391-CR_1644007976000.TAR.GZ
[2022-08-22 11:05:12 AM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2022-08-22 11:05:12 AM] Copying: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2022-08-22 11:05:44 AM] Validating: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2022-08-22 11:05:53 AM] Copied: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[2022-08-22 11:05:53 AM] Checking Existing File: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[2022-08-22 11:05:53 AM] Copying: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[2022-08-22 11:06:09 AM] Validating: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[2022-08-22 11:06:14 AM] Copied: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[2022-08-22 11:06:14 AM] Checking Existing File: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[2022-08-22 11:06:14 AM] Copying: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[2022-08-22 11:06:51 AM] Validating: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[2022-08-22 11:06:58 AM] Copied: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[2022-08-22 11:06:58 AM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2022-08-22 11:06:58 AM] Copying: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2022-08-22 11:08:01 AM] Validating: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2022-08-22 11:08:12 AM] Copied: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[2022-08-22 11:08:12 AM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2022-08-22 11:08:12 AM] Copying: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2022-08-22 11:09:02 AM] Validating: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2022-08-22 11:09:10 AM] Copied: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[2022-08-22 11:09:10 AM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2022-08-22 11:09:10 AM] Copying: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2022-08-22 11:10:06 AM] Validating: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2022-08-22 11:10:15 AM] Copied: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[2022-08-22 11:10:15 AM] Checking Existing File: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[2022-08-22 11:10:15 AM] Copying: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[2022-08-22 11:10:49 AM] Validating: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[2022-08-22 11:10:54 AM] Copied: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[2022-08-22 11:10:54 AM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2022-08-22 11:10:54 AM] Copying: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2022-08-22 11:11:48 AM] Validating: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2022-08-22 11:11:57 AM] Copied: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[2022-08-22 11:11:57 AM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2022-08-22 11:11:57 AM] Copying: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2022-08-22 11:12:52 AM] Validating: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2022-08-22 11:13:01 AM] Copied: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[2022-08-22 11:13:01 AM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2022-08-22 11:13:01 AM] Copying: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2022-08-22 11:14:07 AM] Validating: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2022-08-22 11:14:18 AM] Copied: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[2022-08-22 11:14:18 AM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:14:18 AM] Copying: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:15:13 AM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:15:22 AM] Copied: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[2022-08-22 11:15:22 AM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:15:22 AM] Copying: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:16:18 AM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:16:27 AM] Copied: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[2022-08-22 11:16:27 AM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:16:27 AM] Copying: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:16:27 AM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:16:27 AM] Copied: 4U5T-14G424-CE_1644243346000.TAR.GZ
[2022-08-22 11:16:27 AM] Generating reformat.lst
[2022-08-22 11:16:27 AM] Generating autoinstall.lst
[2022-08-22 11:16:28 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
