"I do not want to jailbreak my APIM.
How can I perform the update manually? Since I have a MY20 APIM (LU5T), I am stuck with memory errors and cannot use the reformat tool. What is the safest procedure to clear the storage and install the new maps without bricking my unit?
Old SYNC Version: 3.4.21194
I’d prefer to avoid jailbreaking. Since my unit is a 2020 MY20, I want to keep the system as stock as possible. What are the alternative methods to wipe old map fragments and perform a clean install?
Already answered → I need to clear the cached map data and do a fresh installation
:warning: If you post again about the same issue / query / concern, you will be silenced.
:locked:
