I’m now trying a different way - I’m trying to download the files firstly using the updater then I will try [o create the updater properly. Wish me luck
You are making things harder than they really are, and to be honest, I’m having issues following what you are doing.
Do this:
Go to Easily Update Your SYNC 3 Using Our Manual Method - CyanLabs , the section you are looking for is " 2. Downloading the update files".
There, set all the configuration you want WITH MAPS, everything. Download all the files into a fresh and empty folder. Once you have everything there, send us a screenshot of that folder with its contents .
Then, you will copy those files, all of them, to whatever folder you configured in Syn3Updater as download path. Send us a screenshot after you are done.
Then , configure Syn3Updater to install the very same versions you put in the webpage.
Before starting the process, send us a screenshot of the Syn3Updater window.
