What is your SYNC Region? Either
What is your current SYNC Version? 3.4
Do you have Navigation? Y
Do you have a error message, if so what is it? No
Can’t atm as sitting in car
I updated from 3.0 to the latest version of 3.4 all went great. Reached green screen and it asked me to put in the usb to continue the update I did so. That gave me an err04 message which reading on here is blocked package I reset the master after this. I was having some glitches so decided to downgrade to an earlier version (the last one with auto lights, sorry in car with no laptop)
This downgrade went fine. Reached green screen etc. It the told me on the main Ford screen to reinsert usb to continue setup. I did this said updates were installing then flashed up a second message saying done. Didn’t catch rest as it black screened. Then we went to a sync 3.0 style display and the installs started again. What did I do wrong. As I got 20m thought I’d ask as don’t want to mess it up lol.
avdonr
(avdonr)
19 March 2021 18:59
2
What exactly are you trying to do? Are you currently in the reformat tool? If you just want to install the last version with auto-brightness then once you reach the green screen and remove the USB you are done.
Do not re-insert the USB again as it will downgrade to 3.3 and reformat once again.
Ok cool guess learn from mistakes there. After the green screen it did the reboot and a pop up asked for the memory stick to be reinserted to continue else features will be disabled. Do I just ignore that?
SaNdMaN
(SaNdMaN)
19 March 2021 19:04
4
I do not know what you are trying to do.
Please, read the tutorial and follow it Easily Update SYNC 3 Using Our Automated Method - CyanLabs
Depending on what you are doing, it tells you exactly when to remove the USB or keep it in
You didn’t provide any log or information, so maybe the installation is starting again because you are not removing the USB when you should.
And you should only remove it once…
I have. Considering it didn’t mention this screen after the green I thought thought I’d ask.
avdonr
(avdonr)
19 March 2021 19:06
6
If you left the USB inserted after the green screen and reboot, that means that SYNC tried to start installing 3.3 again to downgrade. If you remove the USB at the green screen and do not re-insert it, SYNC will not ask for you to re-insert it.
Basically just leave the USB disconnected after the green screen and make sure its removed before it reboots.
That’s what I’d done. Removed at green. It did it’s thing as expected. Rebooted. Usb stick stayed out.
Then on the initial boot it asked me to reinsert to finish (next run I’ll take a pic and show you, only about 10m left). Curious as to why it’s asking.
avdonr
(avdonr)
19 March 2021 19:10
8
After the reboot, make sure to perform a master reset. It shouldn’t be asking for you to insert a USB after a reformat.
Yeah I may ignore it then and do the reset. I will take a pic though just for reference. Very curious I must admit. Thanks for the help new to this so wanted to just ask.
avdonr
(avdonr)
19 March 2021 19:13
10
No worries, curious myself. Would also be useful if you could upload your log at some point (to show the contents of the USB).
Yeah will do on both. Nice even if I’ve done something wrong somewhere. Got to learn somehow. Will iPad log when in.
and I still not plugged it in just ignored and done a master reset
avdonr
(avdonr)
19 March 2021 19:29
13
Very weird. Never seen this before personally. Let me know what happens after a master reset.
nothings come up. im very curious though as did on latest version and this one. so makes you wonder has something not taking right. how do I get a copy of the usb log? ill upload.
also out of curiosity what version do you find runs best? or you on the latest? just curious lol
CYANLABS - SYN3 UPDATER - V2.4.2.0
Branch: Release
Operating System: Microsoft Windows 10 Home (1703)
Version: 3.0.20204
Mode: reformat FORCED
Model: USB SanDisk 3.2Gen1 USB Device 28.6GB
FileSystem: FAT32
GRACENOTES=4U5T-14G423-AB_1598633764000.TAR.GZ
APPS=5U5T-14G381-EM_1611967752000.TAR.GZ
VOICE=5U5T-14G391-AM_1598633466000.TAR.GZ
MAP=1U5T-14G421-BAG_1591726015000.TAR.GZ
MAP=1U5T-14G421-BBG_1591726765000.TAR.GZ
MAP=1U5T-14G421-BCG_1591726913000.TAR.GZ
MAP=1U5T-14G421-BDG_1591727234000.TAR.GZ
MAP=1U5T-14G421-BFG_1591727753000.TAR.GZ
MAP=1U5T-14G421-BGG_1591728190000.TAR.GZ
MAP=1U5T-14G421-BJG_1591729086000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAE_1580861780000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBE_1580861854000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCE_1580861916000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDE_1580862152000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BJ_1591719092000.TAR.GZ
MAP=1U5T-14G421-BHG_1591728542000.TAR.GZ
MAP=1U5T-14G421-BEG_1591727457000.TAR.GZ
; CyanLabs Syn3Updater 2.x - reformat Mode - Sync 3.4.20351 EU
FILES (19)
4U5T-14G423-AB_1598633764000.TAR.GZ (684.9MB)
5U5T-14G391-AM_1598633466000.TAR.GZ (1.5GB)
1U5T-14G421-BAG_1591726015000.TAR.GZ (2.2GB)
1U5T-14G421-BBG_1591726765000.TAR.GZ (451.8MB)
1U5T-14G421-BCG_1591726913000.TAR.GZ (1.6GB)
1U5T-14G421-BDG_1591727234000.TAR.GZ (1GB)
1U5T-14G421-BFG_1591727753000.TAR.GZ (2.3GB)
1U5T-14G421-BGG_1591728190000.TAR.GZ (1.8GB)
1U5T-14G421-BJG_1591729086000.TAR.GZ (22MB)
4U5T-14G422-BAE_1580861780000.TAR.GZ (2.2GB)
4U5T-14G422-BBE_1580861854000.TAR.GZ (2GB)
4U5T-14G422-BCE_1580861916000.TAR.GZ (1.5GB)
4U5T-14G422-BDE_1580862152000.TAR.GZ (1.9GB)
1U5T-14G424-BJ_1591719092000.TAR.GZ (1.7KB)
1U5T-14G421-BHG_1591728542000.TAR.GZ (2.4GB)
1U5T-14G421-BEG_1591727457000.TAR.GZ (1.6GB)
[19/03/2021 06:20:30] Selected Region: EU - Release: Sync 3.4.20351 - Map Version: F9 (2019) - EU (09-2020)
[19/03/2021 06:20:30] Install Mode: reformat
[19/03/2021 06:20:30] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19/03/2021 06:20:30] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[19/03/2021 06:20:30] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[19/03/2021 06:20:31] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[19/03/2021 06:20:31] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[19/03/2021 06:20:40] Validated: 4U5T-14G423-AB_1598633764000.TAR.GZ (Skipping Download)
[19/03/2021 06:20:40] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[19/03/2021 06:20:50] Validated: 5U5T-14G381-EM_1611967752000.TAR.GZ (Skipping Download)
[19/03/2021 06:20:50] Checking Existing File: 5U5T-14G391-AM_1598633466000.TAR.GZ
[19/03/2021 06:21:06] Validated: 5U5T-14G391-AM_1598633466000.TAR.GZ (Skipping Download)
[19/03/2021 06:21:06] Checking Existing File: 1U5T-14G421-BAG_1591726015000.TAR.GZ
[19/03/2021 06:21:28] Validated: 1U5T-14G421-BAG_1591726015000.TAR.GZ (Skipping Download)
[19/03/2021 06:21:28] Checking Existing File: 1U5T-14G421-BBG_1591726765000.TAR.GZ
[19/03/2021 06:21:32] Validated: 1U5T-14G421-BBG_1591726765000.TAR.GZ (Skipping Download)
[19/03/2021 06:21:32] Checking Existing File: 1U5T-14G421-BCG_1591726913000.TAR.GZ
[19/03/2021 06:21:48] Validated: 1U5T-14G421-BCG_1591726913000.TAR.GZ (Skipping Download)
[19/03/2021 06:21:48] Checking Existing File: 1U5T-14G421-BDG_1591727234000.TAR.GZ
[19/03/2021 06:21:58] Validated: 1U5T-14G421-BDG_1591727234000.TAR.GZ (Skipping Download)
[19/03/2021 06:21:58] Checking Existing File: 1U5T-14G421-BFG_1591727753000.TAR.GZ
[19/03/2021 06:22:27] Validated: 1U5T-14G421-BFG_1591727753000.TAR.GZ (Skipping Download)
[19/03/2021 06:22:27] Checking Existing File: 1U5T-14G421-BGG_1591728190000.TAR.GZ
[19/03/2021 06:22:47] Validated: 1U5T-14G421-BGG_1591728190000.TAR.GZ (Skipping Download)
[19/03/2021 06:22:47] Checking Existing File: 1U5T-14G421-BJG_1591729086000.TAR.GZ
[19/03/2021 06:22:47] Validated: 1U5T-14G421-BJG_1591729086000.TAR.GZ (Skipping Download)
[19/03/2021 06:22:47] Checking Existing File: 4U5T-14G422-BAE_1580861780000.TAR.GZ
[19/03/2021 06:23:08] Validated: 4U5T-14G422-BAE_1580861780000.TAR.GZ (Skipping Download)
[19/03/2021 06:23:08] Checking Existing File: 4U5T-14G422-BBE_1580861854000.TAR.GZ
[19/03/2021 06:23:28] Validated: 4U5T-14G422-BBE_1580861854000.TAR.GZ (Skipping Download)
[19/03/2021 06:23:28] Checking Existing File: 4U5T-14G422-BCE_1580861916000.TAR.GZ
[19/03/2021 06:23:42] Validated: 4U5T-14G422-BCE_1580861916000.TAR.GZ (Skipping Download)
[19/03/2021 06:23:42] Checking Existing File: 4U5T-14G422-BDE_1580862152000.TAR.GZ
[19/03/2021 06:24:01] Validated: 4U5T-14G422-BDE_1580862152000.TAR.GZ (Skipping Download)
[19/03/2021 06:24:01] Checking Existing File: 1U5T-14G424-BJ_1591719092000.TAR.GZ
[19/03/2021 06:24:01] Validated: 1U5T-14G424-BJ_1591719092000.TAR.GZ (Skipping Download)
[19/03/2021 06:24:01] Checking Existing File: 1U5T-14G421-BHG_1591728542000.TAR.GZ
[19/03/2021 06:24:25] Validated: 1U5T-14G421-BHG_1591728542000.TAR.GZ (Skipping Download)
[19/03/2021 06:24:25] Checking Existing File: 1U5T-14G421-BEG_1591727457000.TAR.GZ
[19/03/2021 06:24:40] Validated: 1U5T-14G421-BEG_1591727457000.TAR.GZ (Skipping Download)
[19/03/2021 06:24:40] Preparing USB drive
[19/03/2021 06:24:40] Formatting USB drive
[19/03/2021 06:24:40] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[19/03/2021 06:24:50] Generating reformat.lst
[19/03/2021 06:24:50] Generating autoinstall.lst
[19/03/2021 06:24:50] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19/03/2021 06:24:50] Copying: 1u5t-14g386-cb.tar.gz
[19/03/2021 06:24:50] Validating: 1u5t-14g386-cb.tar.gz
[19/03/2021 06:24:50] Copied: 1u5t-14g386-cb.tar.gz
[19/03/2021 06:24:50] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[19/03/2021 06:24:50] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[19/03/2021 06:24:52] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[19/03/2021 06:24:53] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[19/03/2021 06:24:53] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[19/03/2021 06:24:53] Copying: 4U5T-14G423-AB_1598633764000.TAR.GZ
[19/03/2021 06:25:06] Validating: 4U5T-14G423-AB_1598633764000.TAR.GZ
[19/03/2021 06:25:14] Copied: 4U5T-14G423-AB_1598633764000.TAR.GZ
[19/03/2021 06:25:14] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[19/03/2021 06:25:14] Copying: 5U5T-14G381-EM_1611967752000.TAR.GZ
[19/03/2021 06:25:42] Validating: 5U5T-14G381-EM_1611967752000.TAR.GZ
[19/03/2021 06:25:51] Copied: 5U5T-14G381-EM_1611967752000.TAR.GZ
[19/03/2021 06:25:51] Checking Existing File: 5U5T-14G391-AM_1598633466000.TAR.GZ
[19/03/2021 06:25:51] Copying: 5U5T-14G391-AM_1598633466000.TAR.GZ
[19/03/2021 06:26:59] Validating: 5U5T-14G391-AM_1598633466000.TAR.GZ
[19/03/2021 06:27:19] Copied: 5U5T-14G391-AM_1598633466000.TAR.GZ
[19/03/2021 06:27:19] Checking Existing File: 1U5T-14G421-BAG_1591726015000.TAR.GZ
[19/03/2021 06:27:19] Copying: 1U5T-14G421-BAG_1591726015000.TAR.GZ
[19/03/2021 06:28:55] Validating: 1U5T-14G421-BAG_1591726015000.TAR.GZ
[19/03/2021 06:29:18] Copied: 1U5T-14G421-BAG_1591726015000.TAR.GZ
[19/03/2021 06:29:18] Checking Existing File: 1U5T-14G421-BBG_1591726765000.TAR.GZ
[19/03/2021 06:29:18] Copying: 1U5T-14G421-BBG_1591726765000.TAR.GZ
[19/03/2021 06:29:38] Validating: 1U5T-14G421-BBG_1591726765000.TAR.GZ
[19/03/2021 06:29:42] Copied: 1U5T-14G421-BBG_1591726765000.TAR.GZ
[19/03/2021 06:29:42] Checking Existing File: 1U5T-14G421-BCG_1591726913000.TAR.GZ
[19/03/2021 06:29:42] Copying: 1U5T-14G421-BCG_1591726913000.TAR.GZ
[19/03/2021 06:30:55] Validating: 1U5T-14G421-BCG_1591726913000.TAR.GZ
[19/03/2021 06:31:12] Copied: 1U5T-14G421-BCG_1591726913000.TAR.GZ
[19/03/2021 06:31:12] Checking Existing File: 1U5T-14G421-BDG_1591727234000.TAR.GZ
[19/03/2021 06:31:12] Copying: 1U5T-14G421-BDG_1591727234000.TAR.GZ
[19/03/2021 06:32:00] Validating: 1U5T-14G421-BDG_1591727234000.TAR.GZ
[19/03/2021 06:32:12] Copied: 1U5T-14G421-BDG_1591727234000.TAR.GZ
[19/03/2021 06:32:12] Checking Existing File: 1U5T-14G421-BFG_1591727753000.TAR.GZ
[19/03/2021 06:32:12] Copying: 1U5T-14G421-BFG_1591727753000.TAR.GZ
[19/03/2021 06:33:58] Validating: 1U5T-14G421-BFG_1591727753000.TAR.GZ
[19/03/2021 06:34:22] Copied: 1U5T-14G421-BFG_1591727753000.TAR.GZ
[19/03/2021 06:34:22] Checking Existing File: 1U5T-14G421-BGG_1591728190000.TAR.GZ
[19/03/2021 06:34:22] Copying: 1U5T-14G421-BGG_1591728190000.TAR.GZ
[19/03/2021 06:35:46] Validating: 1U5T-14G421-BGG_1591728190000.TAR.GZ
[19/03/2021 06:36:05] Copied: 1U5T-14G421-BGG_1591728190000.TAR.GZ
[19/03/2021 06:36:05] Checking Existing File: 1U5T-14G421-BJG_1591729086000.TAR.GZ
[19/03/2021 06:36:05] Copying: 1U5T-14G421-BJG_1591729086000.TAR.GZ
[19/03/2021 06:36:06] Validating: 1U5T-14G421-BJG_1591729086000.TAR.GZ
[19/03/2021 06:36:06] Copied: 1U5T-14G421-BJG_1591729086000.TAR.GZ
[19/03/2021 06:36:06] Checking Existing File: 4U5T-14G422-BAE_1580861780000.TAR.GZ
[19/03/2021 06:36:06] Copying: 4U5T-14G422-BAE_1580861780000.TAR.GZ
[19/03/2021 06:37:44] Validating: 4U5T-14G422-BAE_1580861780000.TAR.GZ
[19/03/2021 06:38:06] Copied: 4U5T-14G422-BAE_1580861780000.TAR.GZ
[19/03/2021 06:38:06] Checking Existing File: 4U5T-14G422-BBE_1580861854000.TAR.GZ
[19/03/2021 06:38:06] Copying: 4U5T-14G422-BBE_1580861854000.TAR.GZ
[19/03/2021 06:39:39] Validating: 4U5T-14G422-BBE_1580861854000.TAR.GZ
[19/03/2021 06:39:59] Copied: 4U5T-14G422-BBE_1580861854000.TAR.GZ
[19/03/2021 06:39:59] Checking Existing File: 4U5T-14G422-BCE_1580861916000.TAR.GZ
[19/03/2021 06:39:59] Copying: 4U5T-14G422-BCE_1580861916000.TAR.GZ
[19/03/2021 06:41:09] Validating: 4U5T-14G422-BCE_1580861916000.TAR.GZ
[19/03/2021 06:41:25] Copied: 4U5T-14G422-BCE_1580861916000.TAR.GZ
[19/03/2021 06:41:25] Checking Existing File: 4U5T-14G422-BDE_1580862152000.TAR.GZ
[19/03/2021 06:41:25] Copying: 4U5T-14G422-BDE_1580862152000.TAR.GZ
[19/03/2021 06:42:50] Validating: 4U5T-14G422-BDE_1580862152000.TAR.GZ
[19/03/2021 06:43:09] Copied: 4U5T-14G422-BDE_1580862152000.TAR.GZ
[19/03/2021 06:43:09] Checking Existing File: 1U5T-14G424-BJ_1591719092000.TAR.GZ
[19/03/2021 06:43:09] Copying: 1U5T-14G424-BJ_1591719092000.TAR.GZ
[19/03/2021 06:43:09] Validating: 1U5T-14G424-BJ_1591719092000.TAR.GZ
[19/03/2021 06:43:09] Copied: 1U5T-14G424-BJ_1591719092000.TAR.GZ
[19/03/2021 06:43:10] Checking Existing File: 1U5T-14G421-BHG_1591728542000.TAR.GZ
[19/03/2021 06:43:10] Copying: 1U5T-14G421-BHG_1591728542000.TAR.GZ
[19/03/2021 06:45:00] Validating: 1U5T-14G421-BHG_1591728542000.TAR.GZ
[19/03/2021 06:45:25] Copied: 1U5T-14G421-BHG_1591728542000.TAR.GZ
[19/03/2021 06:45:25] Checking Existing File: 1U5T-14G421-BEG_1591727457000.TAR.GZ
[19/03/2021 06:45:25] Copying: 1U5T-14G421-BEG_1591727457000.TAR.GZ
[19/03/2021 06:46:37] Validating: 1U5T-14G421-BEG_1591727457000.TAR.GZ
[19/03/2021 06:46:53] Copied: 1U5T-14G421-BEG_1591727457000.TAR.GZ
[19/03/2021 06:46:53] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
avdonr
(avdonr)
19 March 2021 19:44
16
Well a master reset basically forces SYNC to relearn all vehicle details and parameters from the as-built so it might have cleared out whatever flag was set for the USB install message. At least its gone now.
I am running the latest build (3.4.20351) as I find it to be the fastest and most stable. I also like the audio screen redesign that’s present in 3.4.20196 and higher. If you need the auto-brightness toggle then you can’t really update to a later version which is unfortunate. There is no workaround as of right now.
Based on your log you uploaded, it makes sense why it keeps reformatting. The 3.4 build you are on has not yet blacklisted the reformat package so it loops back into the reformat tool if you plug in the USB again. Newer 3.4 builds have the reformat package blacklisted which is why a downgrade is first required.
Maybe its something left there, curious though.
i also noticed with this build my climate option shows but not on latest. i found 20351 to keep freezing on mine. perhaps ill try the 20196 build let the latest bed in etc.
that does make sense as to why it didnt like it in there the first time and reformatted now. thanks. I presume if i update to 20196+ and leave the maps (already latest now) it shouldnt matter as much.
thanks for your help its been really appreciated
avdonr
(avdonr)
19 March 2021 19:50
18
No worries. As for your climate menu, this was a change that Ford intentionally made. They enabled the climate menu for vehicles that were not supposed to have it so technically it not showing is what is intended to happen. Of course, you can always re-enable the climate menu with FORScan.
Ahh, was nice to have it back, but not to bothered the sides are flipped for me anyway so better its not there imo. just to check when i update with no maps its just autoinstall this time?
avdonr
(avdonr)
19 March 2021 20:07
20
Yeah autoinstall is fine. There are no newer maps than NA 1 19.
