cool and no master resets needed lol. and thats ok tbf not too bothered with maps car play fixes that. but always nice to do latest just incase
Why does people force methods itâs beyond me.
Why did you force REFORMAT?.
If after a successful operation Sync still says that thereâs a pending update, it may be a strange case where the APIM has a flag thatâs there a pending update.
That wonât be cleared by a Master Reset.
So what you need to do is whatâs said in the message Iâve just quoted
This is what I was thinking too, but @Ninja_tiger stated that the message didnât come back up after he did the master reset which leads me to believe that itâs something else (who knows with SYNC). It seems to be working fine now, so itâs likely best to leave it be in my opinion.
I just went through the automatic selections. typed my version in what I was going to and let it do the rest. unless ive overseen an option.
its curious the master reset cleared it but also on both perhaps if there is something flagged in the APIM where ive dropped back and then back up again could fix it - no reformat options are selected so ill just let it do its thing no blocks etc - I guess
no its not come back even left the car for a bit to try - just incase. maybe it is as you said SYNC being SYNC
An option is âforcedâ when you select an option here other than âautodetectâ:
You must have selected reformat. Regardless, it still worked out for you since you were coming from 3.0 to 3.4 (and an older build of 3.4 at that).
ahh that makes sense I think as was my first time I followed a YouTube video - just to make sure I missed nothing and he was 3.0 to 3.4 so I did what he did and that was the option he used. Makes sense though - thanks for showing me
No problem. In the future if you want to change the build you are on or something just let it autodetect and make sure you put in your correct current version up top. The app will handle everything for you to ensure the process goes smoothly.
Will do in future. I suppose as long as you let the app update the version it will do the leg work for you. im curious as to the update with no format options this time will the update message clear or not. will keep you updated lol. tomorrow though I had enough for one day updating haha
Yeah of course. I have no doubt that updating to a newer/older build without reformatting will clear that message. It only comes up when an existing update has been interrupted (which is why I found it strange that it came up directly after a reformat). Anyways, thereâs lots of experimenting you can do with the app to find the solution that works best for you.
Yes, this is the case.
The error you are seeing is not a failed installation, rather the continued installation of maps, etc. If you wait for this to finish it will go away by itself. This error clears on a master reset or subsequent reboot of the APIM. You can run the APIM Interrogator to see if there is a a DTC set in the APIM, or look with FORScan. Open the XML file in a browser.
hi, I did the update to the latest version. it ran its course and no message. thanks everyone
