Interrogator documentation - up to date?
Hey,
i created a interrogator usb via the sync tool, automatic.
However in the documentation Tutorial: APIM Interrogator Utility/Create Interrogator Log it states
You will need to edit the autoinstall.lst file so it looks like the example below:
 Item1 = GB5T-14G386-AC_1587495565000.TAR.GZ
 Open1 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
do i need to edit the autoinstall file yes or no? :slight_smile:
since my tries dont work, the stick is plugged in and the sync says “update installed” etc. but i get no log from the car… i wonder if i have to edit the autoinst file like the doc. states!
Ford Grand C Max, with NAV EU. Year 2018, Titanium. Came with 3.0 build something and its on 3.0 19205. Parking sensors audio and on screen, automatic parking feature. No cameras.
CYANLABS - SYN3 UPDATER - V2.3.1.0
Branch: Release
Version: 3,0,19205
Mode: autoinstall
USB DETAILS
Model: JetFlash Transcend 16GB USB Device 15GB
; CyanLabs Syn3Updater 2.x - Autoinstall Mode - Interrogator Log Utility
Item1 = TOOL - GB5T-14G386-AD_1606255780000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AD_1606255780000.TAR.GZ
SYNCMYRIDE FILES (1)
GB5T-14G386-AD_1606255780000.TAR.GZ (46,1KB)
[25.02.2021 10:57:13] Selected Region:  - Release: Interrogator Log Utility - Map Version:
[25.02.2021 10:57:13] Install Mode: autoinstall
[25.02.2021 10:57:13] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[25.02.2021 10:57:13] Validated: GB5T-14G386-AD_1606255780000.TAR.GZ (Skipping Download)
[25.02.2021 10:57:13] Preparing USB drive
[25.02.2021 10:57:13] Formatting USB drive
[25.02.2021 10:57:13] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[25.02.2021 10:57:20] Generating Autoinstall.lst
[25.02.2021 10:57:20] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[25.02.2021 10:57:20] Copying: GB5T-14G386-AD_1606255780000.TAR.GZ
[25.02.2021 10:57:20] Copied: GB5T-14G386-AD_1606255780000.TAR.GZ
[25.02.2021 10:57:20] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
From the documentation link that you referenced:
If the above file fails to run because you have an older APIM and/or Sync 3.0, use file GB5T-14G386-AB_134244.tar.gz Interrogator Logger.
If you haven’t, try that as per documented
shoudl have read the last sentence. I just expected the Automode does the brainwork :smiley: ill try
It should, I agree.
Let us know how it went with the other file, ok?
AB is needed for 3.0? if some one can confirm what file is needed for each version i’ll tweak the Syn3 Updater code to handle it properly
will do today.
i edited the file by Options = Delay,Include,Transaction
and i put the “older” interr. logger on the stick.
Options are not that relevant, but make sure the references for the file are changed
I’m sure @F150Chief can answer this one.
EDIT: I knew I read something about this.
Here’s the link
i can confirm the build in sync update tool interrogator version did not work for me.
Ford grand c max, manufactured in year 2018?!, sync 3.0.19205 with nav f9
i put the GB5T-14G386-AB onto the stick and a log was created instantly. Waited for the sync to load and the i plugged in the usb. No restart necessary.
With the v GB5T-14G386-AD it did not work at all. Also: the car also said “system restart” but nothing happend. Glad it didnt crash hehe.
would it help you guys uploading the logfile?
just browsed the log… weird that many things are marked as “not present”.
like Heated Windshield HMI (which i have front and rear).
hope the planned 3.4 sync update tomorrow wont crash my apim :smiley:
Thanks, Added to my ToDo list which was at 20 then down to 4 and now back up to 8 :frowning:
VIN: xxxxxxxxxxxxxxxxx
Sync Version: JR3T-14G381-AS
APIM-Modell: JS7T-14G371-NFB
APIM-Typ: Navigation
APIM Größe: 64GB
APIM Freier Speicherplatz: 13G
25.02.2021 12:07:12 +00:00
Partition Type = Free / Total
/fs/usb0/ = 15G / 15G
/fs/tmpfs/ = 126M / 128M
/fs/sd/MAP/ = 35M / 21G
/fs/Nuance/ = 46M / 17G
/fs/Nuance/ = 7.6M / 1.9G
/fs/Nuance/grace = 6.1M / 1.0G
/fs/rwdata/ = 701M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 13G / 55G
APIM AsBuilt (Ford/UCDS)
DE00: 096865929002BC150002
DE01: 474D01064003080000000005
DE02: 0000010000
DE03: 01001601040007
DE04: 17A2179828BE
DE05: 80
DE06: 17033300000000068200000430650064
let me know if the detailed log would help. I can provide it.
It’s extremely hard to completely kill the APIM unless you are MY2020 and don’t read the warning :slight_smile: almost everything is recoverable
just donated. Ahead of my update hehehe, but you guys rock.
I have never been able to find which version changed to which Interrogator file. For instance, -AC works on 3.2 thru 3.4, and I have seen it work on late versions of 3.0, but not on early versions like Sync 3 2.2 or 2.3. I tried -AD on Sync 3 3.0 and it did not work for me. So basically, this is what I know from testing:
AD does not work on Sync 3.0.
AD works on 3.4 late versions.
AC works on 3.2 thru 3.4.
AB works on 3.0 all versions.
I know this is not absolute, but I don’t have the ability to test further.
Looks like you should be fine. It will take about 60 minutes with maps, so keep the ignition on. Battery charger is a good idea, or just go for an hour long drive.
Are we sure it’s related to software version and not hardware models?
It could very well be pre-18.5 and post-18.5 MY differences. I don’t have the hardware to test.
I only have 2 APIM’s currently and one is faulty so neither do i unfortunately.
