ABS
(Adam Ben Starry)
12 August 2021 22:01
1
I successfully upgraded from 3.0.20204 to 3.4.21194.
I then created a Interrogator Log USB and thing seems to go ok when I ran it. However when I tried to open the log in Syn3 Updater (2.10.3.0 Stable) it said the xml file could not be read.
Not sure what the problem is.
When I opened the file in internet explorer this is what I saw:
(Vin redacted)ECU CONSUMER OTA SYNCGEN3 OTA 7D0 5U5T-14G381-ET false 345535542d3134473432312d434a44000000000000000000345535542d3134473432312d434844000000000000000000345535542d3134473432312d434744000000000000000000345535542d3134473432312d434644000000000000000000345535542d3134473432312d434544000000000000000000345535542d3134473432312d434444000000000000000000345535542d3134473432312d434344000000000000000000345535542d3134473432312d434244000000000000000000345535542d3134473432312d434144000000000000000000355535542d3134473339312d435000000000000000000000345535542d3134473432322d434348000000000000000000345535542d3134473432322d434248000000000000000000345535542d3134473432322d434148000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 false 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 false Blank false Blank false Blank true Blank true Blank true Blank true Blank true Blank true Blank true
SaNdMaN
(SaNdMaN)
12 August 2021 22:26
2
When you created the interrogator, did you configure your current version right in Syn3Updater?
The interrogator is created based on the Sync3 version.
This does not appear to be a valid interrogator log
ABS
(Adam Ben Starry)
13 August 2021 00:06
4
Hello SaNdMan,
Yes I configured the current version to the one I upgraded to: 3.4.21194.
The file that is in the SyncMyRide directory was: GB5T-14G386-AD_1606255780000.TAR.GZ
The root directory contained 2 files: autoinstall.lst & DNTINDX.MSA
DNTXINDX.MSA seems to be an empty file.
autoinstall.lst contained this:
; CyanLabs Syn3Updater 2.10.3.0 Stable - Autoinstall Mode - Interrogator Log Utility
Item1 = TOOL - GB5T-14G386-AD_1606255780000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AD_1606255780000.TAR.GZ
SaNdMaN
(SaNdMaN)
13 August 2021 01:15
5
ABS
(Adam Ben Starry)
13 August 2021 01:34
6
Thanks - Unfortunately I can’t find GB5T-14G386-AC_1587495565000.TAR.GZ in any of the links in the referenced post.
SaNdMaN
(SaNdMaN)
13 August 2021 01:39
7
ABS
(Adam Ben Starry)
13 August 2021 02:00
8
The tutorial you linked to led me to: SYNC 3 APIM Software (IVSU) Database - CyanLabs
I could not find GB5T-14G386-AC_1587495565000.TAR.GZ.
The link you supplied is for GB5T-14G386-AD_1606255780000.TAR.GZ - which is the file I already have.
SaNdMaN
(SaNdMaN)
13 August 2021 02:49
9
Man, ok, I just made a mistake by copying and pasting from one place to another.
But I still stand, for the second time: not sure what you checked, the file is there.
Do not expect everything silver platted
F150Chief
(F150Chief)
13 August 2021 02:50
10
Just copy and paste the file name in the search bar and it comes up…
F150Chief
(F150Chief)
13 August 2021 02:51
11
The correct file for your 2017 hardware with 3.4 is the -AC version.
ABS
(Adam Ben Starry)
13 August 2021 18:20
12
Thanks
So I found GB5T-14G386-AC_1587495565000.TAR.GZ and put that in the SyncMyRide directory.
I modified autoinstall.lst to:
Item1 = TOOL - GB5T-14G386-AC_1587495565000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
And I got the same result…
I then modified the autoinstall.lst to:
Item1 = GB5T-14G386-AC_1587495565000.TAR.GZ
Options = Delay,Include,Transaction
still got the same result
So don’t know what to say — the upgrade went well so I’m not worried.
F150Chief
(F150Chief)
13 August 2021 18:40
13
Just a suggestion, maybe some temp files need purged from other attempts. Perform a Master Reset, then run the utility again. Use the autoinstall file attached and rename the file to GB5T-14G386-AC.TAR.GZ
autoinstall.lst (116 Bytes)
Meaning you got the file written but it was like the original post above…?
This time, even if the file is bad, copy it here so I can look at it.
SaNdMaN
(SaNdMaN)
13 August 2021 20:22
14
Well, this is strange.
I’ve seen in the other thread that you successfully upgraded from 3.0 to 3.4, did you perform a master reset after upgrading?.
ABS
(Adam Ben Starry)
14 August 2021 00:35
15
Yes - As I stated in my original post, the upgrade from 3.0 to 3.4 was successful and I did perform a master reset after the upgrade.
SaNdMaN
(SaNdMaN)
14 August 2021 00:48
16
Understood, try a new master reset to test what f150chief said, and we’ll go from there.
F150Chief
(F150Chief)
Closed
17 August 2021 00:48
17
