marpi82
(Marek Pilch)
April 9, 2025, 10:02pm
1
Hello everyone. A few days ago I bought a Ford S-MAX with Sync3 v2.3.17109, I wanted to update the software to the latest version. First I created Interrogator Log. But when I load this log I get error.
It is safe to update my Sync3 via CyanLabs Syn3Updater?
Log says it is no Nav, but I have Nav
Install Type: Unknown
Old SYNC Version: 2.3.17109
New SYNC Version: 2.3.17109
The XML file you have selected does not contain the expected output
Syn3 Updater has determined you are on 2.3.17109 and may be using overlays
Syn3 Updater is unable to determine the configuration of your APIM
Please request assistance on our forum at https://community.cyanlabs.net
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2021-08-27" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0XXXXXXXXXXXXXX</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue="e1000048"/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JL1T-14G381-AJ</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a4c37542d3134473432342d4241000000000000000000004a4c37542d3134473432312d4241000000000000000000004a4c37542d3134473339312d4142000000000000000000004a4c37542d3134473432322d4241000000000000000000004a4c37542d3134473432332d414100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>2ad97c47</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a5f25a3e</d2p1:Response>
</d2p1:DID>
<d2p1:Response>8a6a059a1002ee4006c2</d2p1:Response>
</d2p1:DID>
<d2p1:Response>474d0104c40b488000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0200000200</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001b00260107</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ba318b02bd0</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>08003300000000186a00005656880070</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
<d2p1:Response>00000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType="Direct Configuraation DID DE08" didValue="DE08">
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
<d2p1:Response>GB5T-14G373-AA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CD</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G380-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G371-FFB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-FB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LX1U0045</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
<d2p1:Response>GB5T-14G379-BA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CD</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>3c:a3:08:39:69:33</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:ODLNetwork d2p1:NetworkDataRate="500" d2p1:NetworkName="HS1" d2p1:NetworkProtocol="CAN" d2p1:DLCName="SAE J1962" d2p1:Pins="6,14"/>
<d2p1:AdditionalAttributes logGeneratedDateTime="2021-08-27T14:48:17+00:00" RAM="1504104448" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/dev/hd0t180" total="21074354176" available="115781600"/>
<d2p1:PartitionHealth type="/dev/hd0t181" total="653069312" available="2097120"/>
<d2p1:PartitionHealth type="/dev/hd0t177" total="133709824" available="2097152"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
SaNdMaN
(SaNdMaN)
April 9, 2025, 10:18pm
2
Hello.
As per the information contained in that log, your APIM is HB5T-14G371-FFB which is not MY20 and can be reformatted, so you can upgrade to 3.4 as long as the screen has not been replaced with a MY20 one.
Now, I would first make sure Android Auto and Car Play works on your current build before going to 3.4. Since your car is from 2016 you may need to change the USB HUB for it.
marpi82
(Marek Pilch)
April 12, 2025, 5:13am
3
Hello again, Android auto worked fine for me, so I decided to install update. Everything went smoothly. Even my USB hub turned out to be compatible with SYNC III 3.4. Here’s my log:
Version: 2.3.17109
Install Mode: Auto-Wykrywanie (reformat)
My20 Protection Enabled: WYŁĄCZONE / Nie dla MY20
Model: SanDisk Ultra Fit USB Device
; CyanLabs Syn3Updater 2.13.3.0 Stable - reformat Mode - Sync 3.4.23188 EU
FILES (20)
1u5t-14g386-cb.tar.gz (8,5MB)
[10.04.2025 06:39:27] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: F13 (2023) - EU (10 2024)
[10.04.2025 06:39:27] Install Mode: Auto-Wykrywanie (reformat) Forced: False
[10.04.2025 06:39:27] MY20 Protection: WYŁĄCZONE / Nie dla MY20
[10.04.2025 06:39:27] Formatting USB drive
[10.04.2025 06:39:27] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[10.04.2025 06:39:35] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10.04.2025 06:39:35] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[10.04.2025 06:39:35] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10.04.2025 06:39:35] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[10.04.2025 06:39:35] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[10.04.2025 06:39:50] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[10.04.2025 06:39:50] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[10.04.2025 06:39:58] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[10.04.2025 06:39:58] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[10.04.2025 06:39:58] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[10.04.2025 06:39:58] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[10.04.2025 06:40:07] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[10.04.2025 06:40:07] Checking Existing File: 1U5T-14G421-BAL_1723658080000.TAR.GZ
[10.04.2025 06:40:38] Validated: 1U5T-14G421-BAL_1723658080000.TAR.GZ (Skipping Download)
[10.04.2025 06:40:38] Checking Existing File: 1U5T-14G421-BBL_1723560114000.TAR.GZ
[10.04.2025 06:40:44] Validated: 1U5T-14G421-BBL_1723560114000.TAR.GZ (Skipping Download)
[10.04.2025 06:40:44] Checking Existing File: 1U5T-14G421-BCL_1723600422000.TAR.GZ
[10.04.2025 06:41:03] Validated: 1U5T-14G421-BCL_1723600422000.TAR.GZ (Skipping Download)
[10.04.2025 06:41:03] Checking Existing File: 1U5T-14G421-BDL_1723600797000.TAR.GZ
[10.04.2025 06:41:15] Validated: 1U5T-14G421-BDL_1723600797000.TAR.GZ (Skipping Download)
[10.04.2025 06:41:15] Checking Existing File: 1U5T-14G421-BEL_1723601194000.TAR.GZ
[10.04.2025 06:41:35] Validated: 1U5T-14G421-BEL_1723601194000.TAR.GZ (Skipping Download)
[10.04.2025 06:41:35] Checking Existing File: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 06:41:36] Validate: 1U5T-14G421-BFL_1723601450000.TAR.GZ (Failed!, Downloading)
[10.04.2025 06:41:36] Downloading: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 06:51:56] Validating: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 06:52:15] Downloaded: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 06:52:15] Checking Existing File: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 06:52:15] Downloading: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 07:02:02] Validating: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 07:02:13] Downloaded: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 07:02:13] Checking Existing File: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 07:02:13] Downloading: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 07:13:37] Validating: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 07:13:51] Downloaded: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 07:13:51] Checking Existing File: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 07:13:51] Downloading: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 07:14:02] Validating: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 07:14:03] Downloaded: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 07:14:03] Checking Existing File: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 07:14:03] Downloading: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 07:24:59] Validating: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 07:25:12] Downloaded: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 07:25:12] Checking Existing File: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 07:25:12] Downloading: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 07:35:08] Validating: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 07:35:20] Downloaded: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 07:35:20] Checking Existing File: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 07:35:20] Downloading: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 07:43:05] Validating: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 07:43:14] Downloaded: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 07:43:14] Checking Existing File: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 07:43:14] Downloading: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 07:51:32] Validating: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 07:51:42] Downloaded: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 07:51:42] Checking Existing File: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 07:51:42] Downloading: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 07:51:44] Validating: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 07:51:44] Downloaded: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 07:51:44] Preparing USB drive
[10.04.2025 07:51:44] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10.04.2025 07:51:44] Copying: 1u5t-14g386-cb.tar.gz
[10.04.2025 07:51:44] Validating: 1u5t-14g386-cb.tar.gz
[10.04.2025 07:51:45] Copied: 1u5t-14g386-cb.tar.gz
[10.04.2025 07:51:45] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10.04.2025 07:51:45] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[10.04.2025 07:51:45] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[10.04.2025 07:51:45] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[10.04.2025 07:51:45] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[10.04.2025 07:51:45] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[10.04.2025 07:52:39] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[10.04.2025 07:52:55] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[10.04.2025 07:52:55] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[10.04.2025 07:52:55] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[10.04.2025 07:53:37] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[10.04.2025 07:53:43] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[10.04.2025 07:53:43] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[10.04.2025 07:53:43] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[10.04.2025 07:53:47] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[10.04.2025 07:53:47] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[10.04.2025 07:53:47] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[10.04.2025 07:53:47] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[10.04.2025 07:54:42] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[10.04.2025 07:54:50] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[10.04.2025 07:54:50] Checking Existing File: 1U5T-14G421-BAL_1723658080000.TAR.GZ
[10.04.2025 07:54:50] Copying: 1U5T-14G421-BAL_1723658080000.TAR.GZ
[10.04.2025 07:58:06] Validating: 1U5T-14G421-BAL_1723658080000.TAR.GZ
[10.04.2025 07:58:28] Copied: 1U5T-14G421-BAL_1723658080000.TAR.GZ
[10.04.2025 07:58:28] Checking Existing File: 1U5T-14G421-BBL_1723560114000.TAR.GZ
[10.04.2025 07:58:28] Copying: 1U5T-14G421-BBL_1723560114000.TAR.GZ
[10.04.2025 07:59:33] Validating: 1U5T-14G421-BBL_1723560114000.TAR.GZ
[10.04.2025 07:59:38] Copied: 1U5T-14G421-BBL_1723560114000.TAR.GZ
[10.04.2025 07:59:38] Checking Existing File: 1U5T-14G421-BCL_1723600422000.TAR.GZ
[10.04.2025 07:59:38] Copying: 1U5T-14G421-BCL_1723600422000.TAR.GZ
[10.04.2025 08:04:18] Validating: 1U5T-14G421-BCL_1723600422000.TAR.GZ
[10.04.2025 08:04:37] Copied: 1U5T-14G421-BCL_1723600422000.TAR.GZ
[10.04.2025 08:04:37] Checking Existing File: 1U5T-14G421-BDL_1723600797000.TAR.GZ
[10.04.2025 08:04:37] Copying: 1U5T-14G421-BDL_1723600797000.TAR.GZ
[10.04.2025 08:07:40] Validating: 1U5T-14G421-BDL_1723600797000.TAR.GZ
[10.04.2025 08:07:52] Copied: 1U5T-14G421-BDL_1723600797000.TAR.GZ
[10.04.2025 08:07:52] Checking Existing File: 1U5T-14G421-BEL_1723601194000.TAR.GZ
[10.04.2025 08:07:52] Copying: 1U5T-14G421-BEL_1723601194000.TAR.GZ
[10.04.2025 08:11:55] Validating: 1U5T-14G421-BEL_1723601194000.TAR.GZ
[10.04.2025 08:12:13] Copied: 1U5T-14G421-BEL_1723601194000.TAR.GZ
[10.04.2025 08:12:13] Checking Existing File: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 08:12:13] Copying: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 08:16:52] Validating: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 08:17:20] Copied: 1U5T-14G421-BFL_1723601450000.TAR.GZ
[10.04.2025 08:17:20] Checking Existing File: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 08:17:20] Copying: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 08:19:38] Validating: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 08:19:57] Copied: 1U5T-14G421-BGL_1723602075000.TAR.GZ
[10.04.2025 08:19:57] Checking Existing File: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 08:19:57] Copying: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 08:22:42] Validating: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 08:23:10] Copied: 1U5T-14G421-BHL_1723602658000.TAR.GZ
[10.04.2025 08:23:10] Checking Existing File: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 08:23:10] Copying: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 08:23:12] Validating: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 08:23:13] Copied: 1U5T-14G421-BJL_1723602553000.TAR.GZ
[10.04.2025 08:23:13] Checking Existing File: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 08:23:13] Copying: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 08:25:43] Validating: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 08:26:07] Copied: 4U5T-14G422-BAL_1723663279000.TAR.GZ
[10.04.2025 08:26:07] Checking Existing File: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 08:26:07] Copying: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 08:28:29] Validating: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 08:28:51] Copied: 4U5T-14G422-BBL_1723666341000.TAR.GZ
[10.04.2025 08:28:51] Checking Existing File: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 08:28:51] Copying: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 08:30:39] Validating: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 08:30:55] Copied: 4U5T-14G422-BCL_1723745202000.TAR.GZ
[10.04.2025 08:30:55] Checking Existing File: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 08:30:55] Copying: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 08:33:05] Validating: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 08:33:25] Copied: 4U5T-14G422-BDL_1723746662000.TAR.GZ
[10.04.2025 08:33:25] Checking Existing File: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 08:33:25] Copying: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 08:33:25] Validating: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 08:33:25] Copied: 1U5T-14G424-BN_1727700842000.TAR.GZ
[10.04.2025 08:33:25] Generating reformat.lst
[10.04.2025 08:33:25] Generating autoinstall.lst
[10.04.2025 08:33:25] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Thanks for the great work and express support!
F150Chief
(F150Chief)
Closed
April 26, 2025, 5:14am
4
