I upgraded my sync 3 in my 18 explorer with a k series (KU5T-14G371-CDF) apim and LT4T-18D818-BC acm. I got everything working properly in the radio. Execpt I can’t get the siriusxm to show in the cluster. I have a 18 limited type 3 IPC running custom firmware (full lcd) everything shows up as it should (nav, am & fm radio) in the cluster execpt when I choose siriusXM as source it just shows 01 with no info. Any ideas on how to fix?
Install Type: OEM Replacement
Old SYNC Version: 3.2
none
For the IPC:
720-05-01 *xxx xxxx xxxx
Entertainment Non-Sync Source - ENSS AM/FM (ENSSAMFM), ENSS CD (ENSSCD), ENSS DAB (ENSSDAB), ENSS Sirius (ENSSS)
Make sure ENSS Sirius is enabled.
For the APIM:
7D0-08-01 xxx* xxxx xxxx
Mobile Navigation (MN), Message Set (MS) (used for non-CGEA 1.3 architectures), X40 Setting (X40), Customer Connectivity Setting (CCS)
Make sure the correct message set is enabled. If the ACM is tuning and accepting commands from the APIM it is probably correct.
This may be a function of the IPC firmware not decoding the messages correctly from the X40 ACM. I have the same issue with a 2019 Nautilus with an X40 upgrade and have heard of other vehicles doing the same, all of which were retrofitted with X40.
