Thank you so much, I just ordered a new APIM…I will let you know what type comes…
Travel Link does pull down from the satalite. This is clear as Travel Link was available for SYNC 2 before TCU’s were a thing. It can use your phone with Sync 4 but it does not with Sync 3. The new ones that use 360L use the TCU and can use your Cell phone to get the travel link info for Sync 4.
Ok thanks for that info, I have a new APIM on order, because the one that I now have in my vehicle came from China and the number is counterfeit and that could be the reason that my travel link may not be working, because I have read on this site that other members say that their travel link is working…
Well guys I just installed my new APIM, and I just want to say that it works great, Travel link SiriusXM station logos are there, I’m gonna try to update it now I currently have 3.4.21098 gonna try to install 3.4.22110…and I want to thank you F150Chief for letting me know that was a counterfeit…
You never know what is done to those units, and it’s nearly impossible to fix sometimes. Glad you got it working.
F150Chief, I updated to 3.4.22110 all went well, but for some reason, when I am driving, my vehicle is on the road then it is not on the road, how can I fix that…
Is there a GPS loss of lock icon on the map?
What region is the new APIM set for?
no gps lost icon, NA, it came from California
I think I had this problem to and if I remember right it was fixed by adjusting the wheel clicks.
wheel clicks, what is that…before I upgraded it was working fine…
Wheel Tick Frequency (WTF)
Should be set to ‘0’ for Sync 3…
7D0-03-01: *xxx-xxxx-xxxx
0=20ms (Default Sync 3)
1=30ms
2=40ms (Default Sync 2)
3=50ms
4=60ms
5=70ms
6=80ms
ok i will check that out
If you post your asbuilt for the APIM I will review it.
Could you fill out your profile for the vehicle year, make and model, please. I keep losing track of who has what…thanks.
I have a 2016 Lincoln MKZ,
asbuilt.txt (8.0 KB)
The info in there is for Sync 2…
Save a backup for the current Sync 3 unit in the vehicle.
Yes, thanks.
The issue is the NAV going off course, right?
Where did you get the info for 7D0-05-xx, 7D0-07-xx? Was this from the previous APIM?
Thank you and have a good night…
I looked up an asbuilt for 1 2017 Lincoln MKZ with Sync 3 from the factory. The specific vehicle values in the APIM are wrong. These values are used to determine the vehicle movement, along with GPS, for the nav. The values for 7D0-05-xx, 7D0-07-xx should be:
7D0-05-01 1BB0 1BB0 2B9E
7D0-05-02 C5A3
7D0-07-01 0C00 3300 001E
7D0-07-02 0000 19B7 00B0
7D0-07-03 0056 5686 0013
7D0-07-04 6B4D
This the factory values for that vehicle’s APIM for reference:
7D0-01-01 AA2A 0503 06BB
7D0-01-02 828B 0206 8B7A
7D0-02-01 5553 0104 F47B
7D0-02-02 0340 D000 00EE
7D0-02-03 0005 E1
7D0-03-01 0000 0202 00DF
7D0-04-01 0100 0300 1CFC
7D0-04-02 0008 E5
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-04 6B4D
F150ChiefLeader
Yes, thanks.
yes I loaded this from the old APIM because it was working good,but the new APIM came pre-programmed with some numbers as well…
but I have changed the numbers with the ones that you sent and so far it seems to working pretty good…
