unfortunately not, I was so impatient to quickly test the interrogator tool thus reformatted USB drive for the interrogator package But i have log file for previous upgrade 21265, if it is of interest.
EDIT:If I compare what autoinstall options were used by stock updater to launch xml logging tool, then it contains options which are missing from file generated by Syn3 updater.
Open1 = SyncMyRide\GB5T-14G386-AC.tar.gz
Options = AutoInstall,Delay,Include,Transaction
Hi, Michael
Thanks bro, I love Czech and I’m big fan of Czech beer (this is why my fave beer label on avatar) but I’m not even close to Czechia I have some sh**ty no-name ELM327 BT adapter but this doesn’t work correctly even with simplest mobile apps.
Thanks, appreciate
OK, now I tried all of them and no luck, all 4 files contains FFFF… rows.
Seems, this is the glitch of particular configuration of mine APIM. There is no need to investigate further, waste of time.
Next time I will perform reformat upgrade, as @SaNdMaN suggested, maybe it will change something.
@CyanLabs
by adding these options, my APIM didn’t restart anymore after every log generation procedure. Previously it informed “Update successful, please remove USB. Changes will take effect after reboot” and shortly after that performed unattended restart.
Your eMMC is corrupted, I have troubleshot this before and found this. Refprmat can fix it depending on the extent of the corruption. This is usually due to failed eeprom sections or storage.
The fact that you ran all interrogator versions against a 3.4 unit and all of them produce the same file (even the ones that are not supposed to work on 3.4) tells us there’s something really wrong with your APIM…
thanx for the diagnose @F150Chief
So, it became corrupted during reformat upgrade I performed initially. @SaNdMaN suggested me to reformat again during next update, which shows you both are thinking in the same way about the root cause of the issues.
