Hello everyone
I have lincoln navigator 2018
360 camera and rear show me blue
The problem i am in Ukraine and no offical service can fix it
Please can some one explain me or help me for that
And i can pay fee for that
Please
This is a little odd, but the unit is the original based on the serial number. The tag however shows another part number series, but that is not uncommon with Ford parts. This is a different model of Sync 3 but should be compatible and should support the 10" screen and the cameras, etc.
This is the original APIM Sync unit for your vehicle listed in the factory build sheet.
F10A>GB5T-14G379-AA
F110>DSHB5T-14G371-CA
F111>HL1T-14G380-BB F113>JL7T-14G371-KED APIM Assembly Part Number
F124>HB5T-14G375-CA
F12B>JL7T-18B955-UB
F12C>JJ-013042-A F141>WX377DJQ APIM Serial Number
F142>JLUD805093
F16B>HB5T-14G379-GA
F188>HB5T-14G374-CA
I suspect the issue is the IPMB which controls the 360 cameras. This is mounted behind the APIM in the dash. This will be a part number similar to JL3T-19H423-AD.
You need to get a code reader and see if there are any DTCโs in the vehicle describing the issue.
This should be in your vehicle. It is the IPMB module from the factory.
7B1
F10A>JL7T-14F022-AE
F110>DSJL7T-19H423-AG
F111>HC3T-14F023-DG
F113>JL7T-19H423-AG IPMB Part Number
F188>JL7T-14F017-AG
F18C>13182764875501
Is all the wiring in the first picture from troubleshooting the issue or is that some type of retrofit? Why is the vehicle disassembled like this? Are you trying to add a video source to the APIM with 360 view? If so you will need an external switch for the video. There are kits made for this which are plug and play on eBay.
Really agin thank youuuuuuuu
This part JL7T-19H423-AG i bought second one in ebay and show us the same problem blue screen
In program didnโt show any errors
And we check all wires and all is fine !!
About photo no all cable in the place and this test from person who try to check cameraโs is working or not
All cables is ok and no one edite or chenge them !!
But the camera show blue in screen and when person try to run all cameraโs in other monitor its working!!!
That is i am asking about this part
jl7z-14g371
jl7t- 14g532
Which one support my car and two is show me its work from 2018 to 2021 !!
And if i want to chenge all this part to new ? Is possible snd can found them ?
So sorry so many question but really need help and you are great man
Your asbuilt is correct for the 360 view at 7D0-02-01 xxxx xxxx *x-- from the factory.
7D0-02-01 5553 0F04 F489
What is the APIM asbuilt values there now?
Also, have you run the LIN Bus Calibration for the IPMB cameras? This must be done when switching modules for the IPMB to address the cameras. This is in FORScan programming.
No, that is a dealer service procedure, not FORScan.
I would not use either of those if you are looking to replace the APIM. You should use FORScan to perform the LIN calibration before you do anything else.
