Logs erro
I’m going to try to update the maps on my unit, but the car is imported from the United States and I don’t know if there are any changes, so I created the USB PEN Interrogatory logs, but when I try to open the logo it gives an error in the application.
Currently, when I try to see something on the map, only a red arrow appears, and that the closest address is 9,000kms away and I have information that the map version is F12.
What is the best way to have maps available for Portugal. Thanks
Install Type: Unknown
Old SYNC Version: 3.4.23188
The XLM file you have selected Could not be read,…
Syn3 Updater Version: 2.13.0.0.
…'x    ¸“ŸY¹“ŸY¸“ŸY d          À %"A  b
   b       Á u t l o g g i n g u t i l i t Á y . I n t e r l o g _ u t i l Á i t y . l o g                 …m-    ¹“ŸY¹“ŸY¹“ŸYdd          À «!  3*             3*      Á I n t e r r o g a t o r _ L o Á g . x m l        1:Response>
          </d2p1:DID>
            <d2p1:Response>00000900060001</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1856195a29d6</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>100033000000000b65000056566d004c</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>DS-1U5T-14G371-DA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G380-EE</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>4U5T-14G371-CJA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G375-DA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>WY4070N0</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G374-DA</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>0c:1c:57:5b:92:e3</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>0c:1c:57:5b:92:e4</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2024-12-31T18:29:50+00:00" RAM="1107513344" vmcuVersion="Vector_VMCU_05.04.13">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.2G" available="804K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.9G" available="15M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.8G" available="21M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.3G" available="4.5M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="26M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="3.7G" available="36M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.9G" available="91M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="731M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="89M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
      <d2p1:PartitionHealth type="/fs/mp/resources" total="91M" available="260K"/>
      <d2p1:PartitionHealth type="/fs/images/" total="25G" available="3.4G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
Hi.
Do not copy and paste, send the xml file instead.
Sync_WY4070N0_1FATP8UH1K5177224.xml (10.5 KB)
Which interrogator utility did you use? This file is truncated with no XML header.
However, Your APIM is 4U5T-14G371-CJA, which is safe to reformat. You will need to reformat the APIM and use the EU Cut Down maps for your region. This tutorial will help understand the process, which you can use the Syn3 Updater to accomplish.
Cut Down Map Package Generator - CyanLabs
Tutorial: Current EU Maps Installation on US Imported Vehicles - Ford / Guides - CyanLabs Official Community
