That voice file takes about 1.5GB of uncompressed space, there’s another version that contains Brazilian Portuguese that’s a bit smaller: 5U5T-14G391-DS (about 1GB)…
So share the interrogator log once you are able to so that we can see if we can fit something on the unit.
It worked, thank you very much, if Ford had spent 5 dollars more on 16GB it wouldn’t have had this problem on the basic 6.5 apim.
One question is whether it is possible to replace the internal memory, like is it a micro SD or is it soldered?
Awesome!, glad it worked.
Just remember that you will have to do this in the future should you decide to upgrade again in the future… It would be nice to see how much free space the unit has now with the “correct” voice package installed… Could you please re-run an interrogator log and share the results?.
It’s odd you had issues with the install Syn3updater gave you… maybe we can tweak that… maybe not…
In all fairness, you were never supposed to have 3.4 running on your vehicle, so these issues are expected to happen and Ford can’t be really be blamed here…
No, you can’t expand the internal storage, you would have to look into getting a new APIM with more storage… 16 GB if you do not want to add Navigation or a 32GB one if you want NAV.
