map update sync 3.3
What is your SYNC Region?EU
What is your current SYNC Version? 3.3
Do you have Navigation? yes
Do you have a error message, if so what is it?no
I would like to know if it is possible to update only the maps and how to proceed.
Thank you
Hello.
Please read this: Can i update maps only using Ci Build of Syn3 Updater
It should be possible since you are on 3.3, but why do you want to update only maps?
You do not have MY20/+ components right?.
In theory, what you are trying to do may work.
Which map version do you currently have?.
Hi thanks for the reply, the version of my map is nr, 7.
I would like to update only the maps because I am afraid of not being able to update the whole system and I don’t know if it would be possible to go back if something does not work. Thank you
As @SaNdMaN pointed out above, you can update the maps only, or apps and maps. Since you are on Sync 3.3, you will be able to revert back from Sync 3.4 if you wish.
