Master reboot freezes on Continue
I have the latest 3.4 update files to fix my navram problem of going back to AM radio after startup. Currently running CYAN 3.4 23088 but can’t put system back into factory default mode to load newest files. System freezes when Continue is selected.
Old SYNC Version: 3.4.23088
23088 (as 22251) has a bug in which the rwdata partition gets full and the unit exhibits that behavior.
All known methods for recovery are located here → APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates (Solved)
If none of those work, we do not have anything else to recommend.
A user recently shared his experienced, where after 10-20 minutes of trying the SR → SR → MR combo the MR completed correctly, which enabled him to run the rwdata cleaner and then go to the latest version (which has the bug fixed).
