Navigation error
Upgraded to sync 3 from sync2 all went well install fakra GPS everything was working but after restarting car have map error cannot lock onto satellite
Install Type: OEM Replacement
Old SYNC Version: 3.4.21265
New SYNC Version: 3.4.26057
Navigation malfunction
Sync_NW9Y00XF_WF05XXGCC5FK27765.xml
Its an antenna issue, either a junk GPS antenna, bad connector on the APIM or the setting in the AB is wrong.
DE02/7D0-03-01: x*xx-xxxx-xxxx
Values
0=Roof Mount (UK Default)
1=Instrument Panel (IP) Mount (Non Heated Windscreen)
2=Instrument Panel (IP) Mount (Heated Windscreen)
3=Windshield Mount (Non-Heated Windscreen)
4=Windshield Mount (Heated Windscreen)
Cheers had it working then just cannot get a GPS signal, ordered a new antenna then back to Forscan (only want it for the clock ) lol use android auto for maps
Are you sure you have a NAV APIM?
Issues with the clock and the GPS are not unusual with non 3.4 native (G/H/J) non-NAV APIMs, the normal fix is to not go above 3.4.21265
Yeah it’s Def a nav system and was working after install of donor sync 3 system but then just stopped and hasn’t got a GPS signal since I’m ok using Forscan, try better antenna first before re installs or Forscan stuff thanks
Apple and Google use data from the car when your using AA or CP(Reverts to phone is data unavailable). If there is inaccurate data on the Canbus than it can mess with AA & CP and other systems.
