Hi,
I have a Ford with a SYNC 3 Navigation APIM in the EU region. I upgraded the unit from SYNC 3.0 to SYNC 3.4 using CyanLabs Syn3 Updater.
After the update I get the following message on the SYNC screen:
“Navigation fault”
“Navigation is not functioning properly.”
The Navigation menu is present, but navigation is no longer functioning correctly.
I have attached the XML files from before and after the update, as well as a photo of the error.
Some information from the APIM interrogation:
VIN: WF0AXXWPMAHK58252
APIM address: 7D0
APIM OS part number: JR3T-14G381-AY
APIM has Navigation
Region: Europe
Installed navigation packages include:
JL7T-14G424-BA
JL7T-14G421-BA
JL7T-14G422-BA
JR3T-14G391-AE
JR3T-14G423-AB
One thing I noticed in the “after” XML is that the APIM still reports JR3T-14G381-AY as the OS/app package, which appears to correspond to SYNC 3.0.23219. I expected the APIM to report the SYNC 3.4 application package after the upgrade.
Could you please check the attached before/after files and let me know whether the APIM configuration, navigation configuration or map packages are incorrect and what I need to do to restore navigation?
Thank you!
Old SYNC Version: 3.0.23219
Navigation fault — “Navigation is not functioning properly.”
Syn3 Updater Version: 2.14.2.0 Stable
Version: 3.0.23219
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Enforced Downgrade EU
Item1 = APPS - 4U5T-14G381-AN_1552583626000.TAR.GZ
FILES (1)
[7/16/2026 12:12:27 PM] Selected Region: EU - Release: Enforced Downgrade - Map Version: Non Nav APIM
[7/16/2026 12:12:27 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[7/16/2026 12:12:27 PM] MY20 Protection: Disabled / Not MY20
[7/16/2026 12:12:27 PM] Formatting USB drive
[7/16/2026 12:12:27 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[7/16/2026 12:12:34 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[7/16/2026 12:12:37 PM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[7/16/2026 12:12:37 PM] Preparing USB drive
[7/16/2026 12:12:37 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[7/16/2026 12:12:37 PM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[7/16/2026 12:12:54 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[7/16/2026 12:12:56 PM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[7/16/2026 12:12:56 PM] Generating Autoinstall.lst
[7/16/2026 12:12:56 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
