Navigation issue on 3.4/21194
What is your SYNC Region? Belgium
**Do you have Navigation?**yes
What region is your SYNC APIM?
What was your old SYNC Version? 3.4/21098
What is your new SYNC Version? 3.4/21194
**How did you update, Ford Website / CyanLabs Website / Syn3 Updater?**sync 3 updater
  • What version of Syn3 Updater did you use? the latest
  • Have you read the documentation at Syn3 Updater - CyanLabs ?
  • Please paste your log output or provide the URL to your log file below
```In all the previous versions, the navigation work as it should , 19200 and up, F8/F9/F10, no problem, untill updated to 3.4/21194. The map keeps twisting around, it's like it's positioning itself constantly. I've already tried with another antenna, but that didn't worked out. In ucds, I used all the places (in DE02) , IP mount etc,reserved, etc. No luck.
It looks to me that it is a software problem....I reïnstalled F10 ...no luck.
And I do not believe that all of the sudden, the GPS antenna is bricked
Is there a solution to fix this annoying issue?
**Please provide any further details below**
We had some users with that issue, try downgrading Sync to an earlier build to see if it solves it.
Also, I’m assuming you performed a master reset after upgrading.
Thank you for the advice. Every time I do an update, I perform a master reset
Have a look at my post. I had the issue and think it was down to v363 strategy being enabled.
May help or may not
Hi, ok, that is something to investigate. Thank you
@Thierry_Walterus ,
Did you fix your spinning map?
Hi, yes I have fixed it. I loaded the as build from a mondi with similar options and features, which has sync3 build-in from factory, so …a mondi with sync3 original
Thanks Thierry,
I knew with your experience it would not take long. Take care.
Thank you
