Navigation malfunction error message after installing aftermarket GPS antenna
Navigation malfunction error message, and slow map loading after changing to an aftermarket GPS antenna. I recently had to chnage my GPS antenna due to loss of GPS siginal (Common issue 2017 Ford mustang), I replaced it with a highly rated GPS Bingfu atenna from Amazon. But since then the map takes a long time to load, and I occasionally get navigation malfunction message, i press OK and it works as it should. Is the aftermarket antenna causing this issue?
Old SYNC Version: 3.0.2323
Nanigantion malfunction
Version: 3.0.23219
Model: SanDisk Cruzer Force USB Device
MAP=1U5T-14G421-BAM_1748461682000.TAR.GZ
MAP=1U5T-14G421-BBM_1748459859000.TAR.GZ
MAP=1U5T-14G421-BCM_1748460093000.TAR.GZ
MAP=1U5T-14G421-BDM_1748460770000.TAR.GZ
MAP=1U5T-14G421-BEM_1748461035000.TAR.GZ
MAP=1U5T-14G421-BFM_1748461472000.TAR.GZ
MAP=1U5T-14G421-BGM_1748462187000.TAR.GZ
MAP=1U5T-14G421-BHM_1748462644000.TAR.GZ
MAP=1U5T-14G421-BJM_1748462970000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAM_1748464396000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBM_1748464677000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCM_1748464896000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDM_1748465073000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BP_1748959609000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat  Mode - Sync 3.4.23188 EU
FILES (20)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2.5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539.6MB)
1U5T-14G421-BCM_1748460093000.TAR.GZ (1.8GB)
1U5T-14G421-BDM_1748460770000.TAR.GZ (1.1GB)
1U5T-14G421-BEM_1748461035000.TAR.GZ (1.8GB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2.5GB)
1U5T-14G421-BGM_1748462187000.TAR.GZ (2.1GB)
1U5T-14G421-BHM_1748462644000.TAR.GZ (2.6GB)
1U5T-14G421-BJM_1748462970000.TAR.GZ (26MB)
4U5T-14G422-BAM_1748464396000.TAR.GZ (2.4GB)
4U5T-14G422-BBM_1748464677000.TAR.GZ (2.3GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1.8GB)
4U5T-14G422-BDM_1748465073000.TAR.GZ (2.1GB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1.7KB)
[19/02/2026 09:24:18] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: F13 (2024) - EU (09 2025)
[19/02/2026 09:24:18] Install Mode: Auto-Detect (reformat) Forced: False
[19/02/2026 09:24:18] MY20 Protection: Auto-Detect
[19/02/2026 09:24:18] Formatting USB drive
[19/02/2026 09:24:18] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[19/02/2026 09:24:28] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19/02/2026 09:24:28] Downloading: 1u5t-14g386-cb.tar.gz
[19/02/2026 09:24:32] Validating: 1u5t-14g386-cb.tar.gz
[19/02/2026 09:24:32] Downloaded: 1u5t-14g386-cb.tar.gz
[19/02/2026 09:24:32] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 09:24:32] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 09:24:32] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 09:24:32] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 09:24:32] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 09:24:32] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 09:32:16] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 09:32:30] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 09:32:30] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 09:32:30] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 09:35:09] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 09:35:15] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 09:35:15] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 09:35:15] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 09:35:30] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 09:35:30] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 09:35:30] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 09:35:30] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 09:38:59] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 09:39:07] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 09:39:07] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 09:39:07] Downloading: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 09:48:58] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 09:49:20] Downloaded: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 09:49:20] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 09:49:20] Downloading: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 09:51:31] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 09:51:36] Downloaded: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 09:51:36] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 09:51:36] Downloading: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 09:58:33] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 09:58:50] Downloaded: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 09:58:50] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 09:58:50] Downloading: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 10:03:07] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 10:03:18] Downloaded: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 10:03:18] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 10:03:18] Downloading: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 10:09:54] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 10:10:12] Downloaded: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 10:10:12] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 10:10:12] Downloading: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 10:19:27] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 10:19:49] Downloaded: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 10:19:49] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 10:19:49] Downloading: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 10:28:00] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 10:28:19] Downloaded: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 10:28:19] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 10:28:19] Downloading: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 10:38:08] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 10:38:31] Downloaded: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 10:38:31] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 10:38:31] Downloading: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 10:38:38] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 10:38:39] Downloaded: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 10:38:39] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 10:38:39] Downloading: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 10:47:30] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 10:47:53] Downloaded: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 10:47:53] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 10:47:53] Downloading: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 10:56:30] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 10:56:52] Downloaded: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 10:56:52] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 10:56:52] Downloading: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 11:03:41] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 11:03:57] Downloaded: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 11:03:57] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 11:03:57] Downloading: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 11:11:42] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 11:12:00] Downloaded: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 11:12:00] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 11:12:00] Downloading: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 11:12:01] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 11:12:01] Downloaded: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 11:12:01] Preparing USB drive
[19/02/2026 11:12:01] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19/02/2026 11:12:01] Copying: 1u5t-14g386-cb.tar.gz
[19/02/2026 11:12:03] Validating: 1u5t-14g386-cb.tar.gz
[19/02/2026 11:12:03] Copied: 1u5t-14g386-cb.tar.gz
[19/02/2026 11:12:03] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 11:12:03] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 11:12:03] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 11:12:03] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[19/02/2026 11:12:03] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 11:12:03] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 11:15:10] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 11:16:10] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19/02/2026 11:16:10] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 11:16:10] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 11:17:34] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 11:18:00] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19/02/2026 11:18:00] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 11:18:00] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 11:18:07] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 11:18:09] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19/02/2026 11:18:09] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 11:18:09] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 11:19:55] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 11:20:28] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[19/02/2026 11:20:28] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 11:20:28] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 11:25:36] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 11:27:10] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[19/02/2026 11:27:10] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 11:27:10] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 11:28:17] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 11:28:37] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[19/02/2026 11:28:37] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 11:28:37] Copying: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 11:32:18] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 11:33:27] Copied: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[19/02/2026 11:33:27] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 11:33:27] Copying: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 11:35:46] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 11:36:29] Copied: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[19/02/2026 11:36:29] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 11:36:29] Copying: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 11:40:05] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 11:41:12] Copied: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[19/02/2026 11:41:12] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 11:41:12] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 11:46:29] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 11:48:05] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[19/02/2026 11:48:05] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 11:48:05] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 11:52:25] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 11:53:46] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[19/02/2026 11:53:46] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 11:53:46] Copying: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 11:59:19] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 12:01:00] Copied: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[19/02/2026 12:01:00] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 12:01:00] Copying: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 12:01:03] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 12:01:04] Copied: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[19/02/2026 12:01:04] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 12:01:04] Copying: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 12:06:13] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 12:07:47] Copied: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[19/02/2026 12:07:47] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 12:07:47] Copying: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 12:12:40] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 12:14:10] Copied: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[19/02/2026 12:14:10] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 12:14:10] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 12:17:54] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 12:19:01] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[19/02/2026 12:19:01] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 12:19:01] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 12:23:30] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 12:24:53] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[19/02/2026 12:24:53] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 12:24:53] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 12:24:53] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 12:24:53] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[19/02/2026 12:24:53] Generating reformat.lst
[19/02/2026 12:24:53] Generating autoinstall.lst
[19/02/2026 1:24:53] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
You’re getting a timeout on the antenna initializing.
If you look elsewhere on here you’ll find a recommended antenna for folks doing conversions which works better.
I changed the GPS antenna for a diffent make, but still getting the error message. Is there a setting in the APIM that would fix the issue.
Some days there are no error message, and then there are some it happens. The navigation all works.
Could I use forscan to fix it?
Forscan’s settings are only for position, the highest gain is behind heated windshield
