No Map direction in instrument cluster
My APIM (ROW-India) has inbuilt navigation and is working. But map direction is not displayed in my instrument cluster.
Is there any solution?
SYNC Region: ROW
Old SYNC Version: 3.4.23188
New SYNC Version: 3.4.26057
no
Syn3 Updater Version: Syn3 Updater 2.14.2.0(Stable)
Version: 3.4.23188
Region: ROW
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.26057 ROW
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 4U5T-14G424-FCK.tar.gz
Open2 = SyncMyRide\4U5T-14G424-FCK.tar.gz
Item3 = MAP - 4U5T-14G421-FCK.tar.gz
Open3 = SyncMyRide\4U5T-14G421-FCK.tar.gz
[SYNCGen3.0_3.0.1]
Item1 = VOICE - 5U5T-14G391-FT_1660787787000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-FT_1660787787000.TAR.GZ
Item2 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item1 = GRACENOTES - 4U5T-14G423-FC_1615431949000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-FC_1615431949000.TAR.GZ
Item2 = APPS - NU5T-14G381-AE_1778770590000.TAR.GZ
Open2 = SyncMyRide\NU5T-14G381-AE_1778770590000.TAR.GZ
FILES (7)
5U5T-14G391-FT_1660787787000.TAR.GZ (1.4GB)
NU5T-14G381-AE_1778770590000.TAR.GZ (869.9MB)
4U5T-14G421-FCK.tar.gz (2.1GB)
4U5T-14G424-FCK.tar.gz (1.7KB)
[02/06/2026 7:20:05 PM] Selected Region: ROW - Release: Sync 3.4.26057 - Map Version: 2021 Q4 - ROW (India and Sri Lanka)
[02/06/2026 7:20:05 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[02/06/2026 7:20:05 PM] MY20 Protection: Enabled
[02/06/2026 7:20:05 PM] Formatting USB drive
[02/06/2026 7:20:05 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[02/06/2026 7:20:13 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[02/06/2026 7:20:13 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[02/06/2026 7:20:13 PM] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[02/06/2026 7:20:18 PM] Validated: 5U5T-14G391-FT_1660787787000.TAR.GZ (Skipping Download)
[02/06/2026 7:20:18 PM] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[02/06/2026 7:20:21 PM] Validated: 4U5T-14G423-FC_1615431949000.TAR.GZ (Skipping Download)
[02/06/2026 7:20:21 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[02/06/2026 7:20:22 PM] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[02/06/2026 7:20:22 PM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[02/06/2026 7:20:25 PM] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[02/06/2026 7:20:25 PM] Checking Existing File: Ford_IndiaCe21Q4_v5.tgz
[02/06/2026 7:20:32 PM] Validated: Ford_IndiaCe21Q4_v5.tgz (Skipping Download)
[02/06/2026 7:21:52 PM] Extracting: Ford_IndiaCe21Q4_v5.tgz (This may take some time!)
[02/06/2026 7:21:52 PM] Added MultiPackage files to Queue
[02/06/2026 7:21:52 PM] Preparing USB drive
[02/06/2026 7:21:52 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[02/06/2026 7:21:52 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[02/06/2026 7:21:52 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[02/06/2026 7:21:52 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[02/06/2026 7:21:52 PM] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[02/06/2026 7:21:52 PM] Copying: 5U5T-14G391-FT_1660787787000.TAR.GZ
[02/06/2026 7:24:08 PM] Validating: 5U5T-14G391-FT_1660787787000.TAR.GZ
[02/06/2026 7:24:46 PM] Copied: 5U5T-14G391-FT_1660787787000.TAR.GZ
[02/06/2026 7:24:46 PM] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[02/06/2026 7:24:46 PM] Copying: 4U5T-14G423-FC_1615431949000.TAR.GZ
[02/06/2026 7:26:36 PM] Validating: 4U5T-14G423-FC_1615431949000.TAR.GZ
[02/06/2026 7:27:00 PM] Copied: 4U5T-14G423-FC_1615431949000.TAR.GZ
[02/06/2026 7:27:00 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[02/06/2026 7:27:00 PM] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[02/06/2026 7:27:05 PM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[02/06/2026 7:27:06 PM] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[02/06/2026 7:27:06 PM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[02/06/2026 7:27:06 PM] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[02/06/2026 7:28:34 PM] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[02/06/2026 7:28:57 PM] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[02/06/2026 7:28:57 PM] Checking Existing File: 4U5T-14G421-FCK.tar.gz
[02/06/2026 7:28:57 PM] Copying: 4U5T-14G421-FCK.tar.gz
[02/06/2026 7:32:35 PM] Validating: 4U5T-14G421-FCK.tar.gz
[02/06/2026 7:33:33 PM] Copied: 4U5T-14G421-FCK.tar.gz
[02/06/2026 7:33:33 PM] Checking Existing File: 4U5T-14G424-FCK.tar.gz
[02/06/2026 7:33:33 PM] Copying: 4U5T-14G424-FCK.tar.gz
[02/06/2026 7:33:33 PM] Validating: 4U5T-14G424-FCK.tar.gz
[02/06/2026 7:33:33 PM] Copied: 4U5T-14G424-FCK.tar.gz
[02/06/2026 7:33:33 PM] Generating Autoinstall.lst
[02/06/2026 7:33:33 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Usually that’s something you turn on in the cluster settings not the APIM
Assuming this had factory NAV to begin with?
Did you do a master reset after the upload of the latest version to the car?
Yes it is factory nav
Yes
On the cluster settings (the ones accessed through the steering wheel switch packs) look to see if you have it enabled.
Did this EVER work since you’re showing this as a retrofit?
Did you load your factory AB into the unit or have you done any other ForScan mods?
