Here are my configuration .
Original Region : ROW (INDIA)
Nav/Non Nav : Non Nav
Old Version : SYNC 3.0
New Version : 3.4.19274
Method used : WIndows App V 2.0.0.0
Car : Ecosport 2018 Titanium
The update was super easy , Thanks to Cynalabs.
I have found 2 issues .
The splash screen starts with the ST screen (Which i configured using forscan) And when turns off it goes to the ford splash screen .
The navigation direction from android auto is not displaying in the instrument cluster . I have enabled the below features in the IPC module using forscan .
Navigation Screen Repeater : Enabled.
Navigation / Compass : Enabled.
Turn by Turn Navigation : Enabled.
Trip Navigation : Enabled.
Trip Navigation pop up : Enabled.
Each time i connect to the android auto the Navigation changes to "Android Auto " as in the image but not the actual direction .
I even thought this behavior is due to non navigation APIM . And i tried with enabling the navigation using forscan . But its still not working. Please let me know, Am i missing any settings. Please help .
Motorola to Intel: If you have a ‘0’, set to ‘1’. If ‘2’ set to ‘3’, and so on.
Intel to Motorola: If you have a ‘1’, set to ‘0’. If ‘3’ set to ‘2’, and so on.
7D0-01-02 xxxx x*xx xxxx
Mode Man Icon [Climate] (MMI), Climate Control Type (CCT), Surround Sound Available in Occupancy Mode (SSA), Nav Repeater Format (NRF)
0=MMI Disabled, CCT Automatic, SSA Available, NRF Motorola format
1=MMI Disabled, CCT Automatic, SSA Available, NRF Intel format
2=MMI Disabled, CCT Automatic, SSA Not Available, NRF Motorola format
3=MMI Disabled, CCT Automatic, SSA Not Available, NRF Intel format
4=MMI Disabled, CCT Manual, SSA Available, NRF Motorola format
5=MMI Disabled, CCT Manual, SSA Available, NRF Intel format
6=MMI Disabled, CCT Manual, SSA Not Available, NRF Motorola format
7=MMI Disabled, CCT Manual, SSA Not Available, NRF Intel format
You can try using the “easy” method (NOT the asbuilt selection) in FORScan selecting the ST theme to make the shutdown screen ST also. This used to work before 3.4 version. Since you are on the ST theme, you might have to set the theme to something like Ford default then back to ST to get it to work. You are looking for Visual Design Variants toward the end of the list.
A lot of the “exit screens” are hard coded and cannot be changed. The ST theme used to be this way before Sync 3.4.
I tried both the Intel and Motorola format. And did a master reset. It did not work. But what is found out is eachtime I update the IPC asbuilt the navigation shows up and the moment I turn off the ignition and turn on then the navigation goes back to “Andorid Auto” view.
