No update available from original Ford homepage
“Sadly”?, okey.
Do not take this the wrong way, but what’s the point of asking for help or guidance if in the end you keep doing what you feel like doing and hitting the exact same result of maps not installing?. Not to mention that the origin of your “Issue” is that you simply interrupted the process because of not following instructions (which is a recurring theme so it seems) or just not reading before doing stuff.
That’s why I feel this may be my last interaction with this thread… a thread that’s been open for 20 days now…
Having said that, this is what I would do:
  • If the file previously identified is still missing, I would try installing it on its own. I’ve provided a very simple and quick method here No update available from original Ford homepage - #35 by SaNdMaN , yet you tried installing the whole package again which can take hours…
  • If that does not work, maybe there’s not enough space on the APIM for that big file. I would try removing gracenotes and installing the small voice package on the unit to free up more space on the unit (all of these can be created in syn3updater). Then I would try again to install the single map file.
  • Should the upgrade succeed, I would then reinstall the latest gracenotes and proper voice package onto the unit.
If non of these work, I’m out of ideas.
