Problem with Update SYNC3
Good Day Everyone,
I keep encountering error 4U5T-14G422-BCM_1748464896000.TAR.GZ during the update. I have already tried using several different flash drives, but it hasn’t helped. To proceed with the software update, I generated a package containing only the map for Cyprus, as I don’t need the other maps. What can I do in this situation?
Thank You for Help
Old SYNC Version: 3.3.19052
New SYNC Version: 3.4.21265
I don't have the logs; where can I get them?
They are all saved in syn3updater, you should read the doc → Logs Tab - CyanLabs
Your description es super vague… At which time does it fail?
Is the unit NAV?
