Problems with the compass
Hi to all, I have a ford ecosport 1.5 TdCi 2018 100cv and after upgrading the Europe version 3.4.21265 APIM without navigator to the Europe version 3.4.22110 APIM without navigator the compass has stopped moving. For the moment I have downgraded to version 3.4.21265.
Do you have any idea how to solve this problem?
Thanks in advance
SYNC Region: Europe
Navigation Variant: No
Install Type: Unknown / Not Sure
Old SYNC Version: 3.4.21265
New SYNC Version: 3.4.22110
Syn3 Updater Version: 2.10.11.0 (Stable)
CYANLABS - SYN3 UPDATER - V2.10.11.0
Version: 3.4.21265
Install Mode: Riconoscimento automatico (autoinstall)
My20 Protection Enabled: Disattivato / Non MY20
; CyanLabs Syn3Updater 2.10.11.0 Stable - Autoinstall Mode - Sync 3.4.22110 EU
Item1 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item2 = APPS - 5U5T-14G381-EZ_1652218180000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G381-EZ_1652218180000.TAR.GZ
Item3 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item4 = VOICE - 5U5T-14G391-AS_1644006548000.TAR.GZ
Open4 = SyncMyRide\5U5T-14G391-AS_1644006548000.TAR.GZ
FILES (4)
5U5T-14G391-AS_1644006548000.TAR.GZ (1,5GB)
[27/05/2022 09:37:29] Selected Region: EU - Release: Sync 3.4.22110 - Map Version: APIM senza navigatore
[27/05/2022 09:37:29] Install Mode: Riconoscimento automatico (autoinstall) Forced: False
[27/05/2022 09:37:29] MY20 Protection: Disattivato / Non MY20
[27/05/2022 09:37:29] Formatting USB drive
[27/05/2022 09:37:29] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[27/05/2022 09:37:37] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[27/05/2022 09:37:43] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[27/05/2022 09:37:44] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[27/05/2022 09:38:03] Validated: 5U5T-14G381-EZ_1652218180000.TAR.GZ (Skipping Download)
[27/05/2022 09:38:03] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[27/05/2022 09:38:03] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[27/05/2022 09:38:03] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[27/05/2022 09:38:16] Validated: 5U5T-14G391-AS_1644006548000.TAR.GZ (Skipping Download)
[27/05/2022 09:38:16] Preparing USB drive
[27/05/2022 09:38:16] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[27/05/2022 09:38:16] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[27/05/2022 09:38:58] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[27/05/2022 09:39:04] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[27/05/2022 09:39:04] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[27/05/2022 09:39:04] Copying: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[27/05/2022 09:39:55] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[27/05/2022 09:40:02] Copied: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[27/05/2022 09:40:02] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[27/05/2022 09:40:02] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[27/05/2022 09:40:06] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[27/05/2022 09:40:07] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[27/05/2022 09:40:07] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[27/05/2022 09:40:07] Copying: 5U5T-14G391-AS_1644006548000.TAR.GZ
[27/05/2022 09:41:37] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[27/05/2022 09:41:50] Copied: 5U5T-14G391-AS_1644006548000.TAR.GZ
[27/05/2022 09:41:50] Generating Autoinstall.lst
[27/05/2022 09:41:50] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
If you check the feedback thread it’s mentioned that the compass may stop working on some no nav models → Sync 3.4.22110 & 2021 Maps - Feedback & Issues
What’s different from what’s said there, is that you should not have an ROW installation, but EU.
But since symptoms are the same and downgrading solves the issue I would think it’s a bug, as described in the build’s thread.
If so, not much to do since it’s up to Ford.
Thanks, I’ll wait for the bugfix
