Qual versão do sync 3 tem comandos do ar condicionado. Não consigo baixar os mapas para américa do sul
Which latest version of sync3 has the air conditioning controls? How do I download the maps of South America? They are currently blocked.
SYNC Region: ANZ
Old SYNC Version: 3.0.25306
não
Syn3 Updater Version: última versão para windows 10
Não enconrei.
English please…
Every build of Sync3 has HVAC controls, whether they are displayed or not is a matter of what is set in the APIM config.
How to access APIM settings?
They all have the controls, there is not specific builds or vaersions of Sync 3.
Use the Syn3 Updater for the maps, you will need to use the reformat tool to install them.
YOU MUST run the Interrogator Utility to ensure that your APIM is NOT MY20+ before you do anything else…
This is done via ForScan.
Turning on the appearance isn’t the only change, you also have to set the correct climate repeater, type of HVAC, etc.
Validate: 4U5T-14G421-DAJ_1727783760000.TAR.GZ (Failed!, Downloading)
I followed all the steps listed. However, maps from 1.19 to 2.23 in South America remain blocked. The only option that has changed is that I could keep the current maps from before the update. However, since I did the update without the maps, since I couldn’t download the maps, the car’s GPS failed and the map wouldn’t open.
