Radio Station frequency and info text not centered.
I had previously watched a review video on sync 3.4 and there was a section that showed radio text and frequency numbers being center-aligned and not left-hand aligned. However, after recently successfully updating to sync 3.4 from 3.0… from cyanlabs, I’m noticing that the radio info/text is still left-hand aligned on the screen. is this normal?
Old SYNC Version: 3.0.23219
N/A
Syn3 Updater Version: 2.13.1.0
n/a
You could have been seeing a Lincoln version of Sync which is center aligned. Ford version is left aligned. A picture of what you are describing might help.
