What is your SYNC Region? NA (USA)
Do you have Navigation? Non-Nav
What region is your SYNC APIM? NA
What was your old SYNC Version? 3.0.20204
What is your new SYNC Version? STILL 3.0.20204
Do you have a error message, if so what is it? None
How did you update, Ford Website / CyanLabs Website / Syn3 Updater? Sync3 Updater–Gracenote removal utility
What version of Syn3 Updater did you use? 2.10.6.0
Have you read the documentation at Syn3 Updater - CyanLabs ? Yes
(Log files can be found on the root of your USB drive or in%localappdata%\CyanLabs\Syn3Updater\Logs)
Version: 3.0.20204
Model: SCSI DISK USB Device
; CyanLabs Syn3Updater 2.10.6.0 Stable - Autoinstall Mode - Gracenotes Removal
FILES (10)
HB5T-14G386-THB.tar.gz (24.7KB)
HB5T-14G386-TBC.tar.gz (31.9KB)
GB5T-14G386-SC.tar.gz (1.8KB)
JR3T-14G391-BF.tar.gz (1GB)
JR3T-14G381-AX.tar.gz (407.3MB)
JR3T-14G423-BB.tar.gz (736.4MB)
GB5T-14G386-AC.tar.gz (43.1KB)
GB5T-14G386-AB_134244.tar.gz (43.1KB)
Sync_VV4RA882_1FTEW1EP9GKExxxxx.xml (10.1KB)
[10/31/2021 12:44:31 PM] Selected Region: - Release: Gracenotes Removal - Map Version:
[10/31/2021 12:44:31 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[10/31/2021 12:44:31 PM] MY20 Protection: Disabled / Not MY20
[10/31/2021 12:44:31 PM] Formatting USB drive
[10/31/2021 12:44:31 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[10/31/2021 12:44:38 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:38 PM] Downloading: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:39 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:39 PM] Downloaded: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:39 PM] Preparing USB drive
[10/31/2021 12:44:39 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:39 PM] Copying: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:42 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:42 PM] Copied: GB5T-14G386-SC_85041.tar.gz
[10/31/2021 12:44:42 PM] Generating Autoinstall.lst
[10/31/2021 12:44:44 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
VIN: 1FTEW1EP9GKExxxxx
Version JR3T-14G381-AX
APIM Model: Blank
APIM Type: Non-Navigation
APIM Size: 8GB
APIM Free Space: 2.6G
10/31/2021 1:07:34 PM +00:00
Partition Type = Free / Total
/fs/usb0/ = 5.3G / 7.5G
/fs/tmpfs/ = 127M / 128M
/fs/sd/MAP/ = 1.9M / 139M
/fs/Nuance/ = 5.4M / 1.3G
/fs/rwdata/ = 658M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 2.6G / 4.2G
Installed Packages
GB5T-14G421-EH
GB5T-14G424-DH
JR3T-14G391-BF
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
I wanted to remove Gracenotes per the 3.0 to 3.4 instructions, and used the tool inside of Syn3Update to do so.
I later read about the missing Sirius XM channel art and radio logos that might be missing after update (without some APIM reprogramming, which I’m uncomfortable with). Since preparing my 3.4.xxx upgrade USB key, I got cold feet, and when trying to re-select my original version to merely restore the file, it only gives me version 3.3xx and up of Sync3 to select–not my 3.0.20204.
Creating a new profile inside Syn3Update doesn’t solve this. Formatting the USB drive I use doesn’t help fix this.
How would I go about re-installing just the Gracenotes from my 3.0.20204 version (I understand that the version of Gracenotes doesn’t change for quite a few point releases–version 1.1.1.1332)
