Recurring "Navigation Malfunction" on every cold boot after 3.4.26057 + cut-down EU maps (32GB APIM detected as Non-Nav)
Config
  • SYNC Region: EU
  • Navigation Variant: Nav (forced — see below)
  • Manufacturer Year: Pre-MY20 (Not MY20 confirmed)
  • Install Type: OEM
  • Old SYNC Version: 3.0.23219
  • New SYNC Version: 3.4.26057
  • Syn3 Updater app version: 2.14.2.0 (Stable)
  • Vehicle: Turkish-market Ford, VIN WF0DXXWPCDGC27620
  • APIM: HB5T-14G371-DAG — 32GB, Navigation (per your Hardware DB; 30/30 records = 32GB/Nav)
Background
This APIM is very likely a SYNC 2 → SYNC 3 retrofit/overlay: an early interrogator returned “unable to determine configuration / may be using overlays”, ECU Serial Number (F18C) is blank, and Cal-Config (F10A) read “DemoAudioProfile”. It ran perfectly on 3.0.23219 (EU) with Turkey maps and working navigation for a long time before I touched it.
What I did
Using Syn3 Updater v2.14.2.0, I updated SYNC firmware 3.0.23219 → 3.4.26057 (EU).
  • Syn3 Updater detected the APIM as Non-Nav, so I set Navigation = Yes (hardware is genuinely a 32GB Nav unit).
  • Full EU F13 (~26.7GB) does not fit a 32GB APIM, so I used the Cut Down Map Package Generator: Turkey/Balkans tile + Bulgaria/Romania/Ukraine tile + Cyprus + Turkish navigation voice (~13.4GB total).
  • First attempt in Reformat mode failed with PKG_ERR04 (reformat tool blacklisted on 3.4.19274+). Rebuilt in Downgrade mode after updating current version to 3.4.26057
    — install then completed cleanly.
  • After install: maps show F13, navigation works fine.
The problem
After every full power-down / cold boot (e.g. car left off overnight, then started — no master reset performed), navigation shows “Navigation Malfunction / not functioning properly, please visit your dealer.” It only works again right after a fresh reinstall, then breaks on the next cold boot.
Confirmed via fresh interrogator (so it is NOT an AsBuilt issue):
The APIM AsBuilt is byte-identical to the working 3.0 state:
  • DE00 = 0a6a05921002be420682 → Navigation Application = On (Common HMI)
  • Clock Master = BCM
  • Radio Tuner Market = EU (RDS)
  • DE01–DE06 and all part numbers (F110/F111/F113/F124/F188) intact, checksums present.
  • Installed: APPS NU5T-14G381-AE (3.4.26057), map parts 1U5T-14G421-BAM/BBM/BGM/BHM/BJM, nav voice 4U5T-14G422-BDM, MAP_LICENSE 1U5T-14G424-BP. Map partitions are present and full; /fs/images 25G total, 4.9G free.
Question
Since the AsBuilt nav config is correct and unchanged from when it worked, this looks like the cut-down map package (MAP_LICENSE) not surviving cold-boot validation on a non-nav-detected APIM. Is this a known limitation of cut-down maps on a unit Syn3 Updater classifies as Non-Nav? Is there any AsBuilt value or re-generation step to make the cut-down navigation persist across a cold boot, or is a full (non-cut-down) map / 64GB APIM the only reliable route?
I can attach the full interrogator log and Syn3 Updater creator log on request.
Operating System: Microsoft Windows 10 Home Single Language (2009)
Version: 3.0.23219
Model: SanDisk SanDisk 3.2 Gen1 USB Device
APPS=NU5T-14G381-AE_1778770590000.TAR.GZ
MAP=1U5T-14G421-BAM_1748461682000.TAR.GZ
MAP=1U5T-14G421-BBM_1748459859000.TAR.GZ
MAP=1U5T-14G421-BCM_1748460093000.TAR.GZ
MAP=1U5T-14G421-BDM_1748460770000.TAR.GZ
MAP=1U5T-14G421-BEM_1748461035000.TAR.GZ
MAP=1U5T-14G421-BFM_1748461472000.TAR.GZ
MAP=1U5T-14G421-BGM_1748462187000.TAR.GZ
MAP=1U5T-14G421-BHM_1748462644000.TAR.GZ
MAP=1U5T-14G421-BJM_1748462970000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAM_1748464396000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBM_1748464677000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCM_1748464896000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDM_1748465073000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BP_1748959609000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat  Mode - Sync 3.4.26057 EU
FILES (20)
1u5t-14g386-cb.tar.gz (8,5MB)
NU5T-14G381-AE_1778770590000.TAR.GZ (869,9MB)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2,5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539,6MB)
1U5T-14G421-BCM_1748460093000.TAR.GZ (1,8GB)
1U5T-14G421-BDM_1748460770000.TAR.GZ (1,1GB)
1U5T-14G421-BEM_1748461035000.TAR.GZ (1,8GB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2,5GB)
1U5T-14G421-BGM_1748462187000.TAR.GZ (2,1GB)
1U5T-14G421-BHM_1748462644000.TAR.GZ (2,6GB)
1U5T-14G421-BJM_1748462970000.TAR.GZ (26MB)
4U5T-14G422-BAM_1748464396000.TAR.GZ (2,4GB)
4U5T-14G422-BBM_1748464677000.TAR.GZ (2,3GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1,8GB)
4U5T-14G422-BDM_1748465073000.TAR.GZ (2,1GB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1,7KB)
[16.06.2026 16:25:11] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: F13 (2024) - EU (09 2025)
[16.06.2026 16:25:11] Install Mode: Auto-Detect (reformat) Forced: False
[16.06.2026 16:25:11] MY20 Protection: Disabled / Not MY20
[16.06.2026 16:25:11] Formatting USB drive
[16.06.2026 16:25:11] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[16.06.2026 16:25:56] Checking Existing File: 1u5t-14g386-cb.tar.gz
[16.06.2026 16:25:56] Downloading: 1u5t-14g386-cb.tar.gz
[16.06.2026 16:26:05] Validating: 1u5t-14g386-cb.tar.gz
[16.06.2026 16:26:05] Downloaded: 1u5t-14g386-cb.tar.gz
[16.06.2026 16:26:05] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 16:26:05] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 16:26:06] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 16:26:06] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 16:26:06] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 16:26:06] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 16:46:14] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 16:46:20] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 16:46:20] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 16:46:20] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 16:55:40] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 16:55:43] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 16:55:43] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 16:55:43] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 16:56:25] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 16:56:25] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 16:56:25] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 16:56:25] Downloading: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 17:09:33] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 17:09:37] Downloaded: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 17:09:37] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 17:09:37] Downloading: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 17:38:40] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 17:38:50] Downloaded: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 17:38:50] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 17:38:50] Downloading: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 17:51:10] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 17:51:12] Downloaded: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 17:51:12] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 17:51:12] Downloading: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 18:11:14] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 18:11:21] Downloaded: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 18:11:21] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 18:11:21] Downloading: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 18:23:57] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 18:24:02] Downloaded: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 18:24:02] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 18:24:02] Downloading: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 18:33:37] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 18:33:41] Validate: 1U5T-14G421-BEM_1748461035000.TAR.GZ (Failed!, Downloading)
[16.06.2026 18:33:41] Downloading (Attempt #2): 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 18:57:32] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 18:57:38] Validate: 1U5T-14G421-BEM_1748461035000.TAR.GZ (Failed!, Downloading)
[16.06.2026 18:57:38] Downloading (Attempt #3): 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 19:17:57] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 19:18:05] Downloaded: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 19:18:05] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 19:18:05] Downloading: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 19:44:53] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 19:45:03] Downloaded: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 19:45:03] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 19:45:03] Downloading: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 20:06:24] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 20:06:32] Downloaded: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 20:06:32] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:06:32] Downloading: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:20:49] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:20:55] Validate: 1U5T-14G421-BHM_1748462644000.TAR.GZ (Failed!, Downloading)
[16.06.2026 20:20:55] Downloading (Attempt #2): 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:47:34] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:47:44] Downloaded: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 20:47:44] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 20:47:44] Downloading: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 20:48:00] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 20:48:00] Downloaded: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 20:48:00] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 20:48:00] Downloading: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 21:13:01] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 21:13:11] Downloaded: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 21:13:11] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 21:13:11] Downloading: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 21:36:50] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 21:37:00] Downloaded: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 21:37:00] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 21:37:00] Downloading: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 21:54:46] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 21:54:53] Downloaded: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 21:54:53] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 21:54:53] Downloading: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 22:16:35] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 22:16:43] Downloaded: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 22:16:43] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 22:16:43] Downloading: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 22:16:44] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 22:16:44] Downloaded: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 22:16:44] Preparing USB drive
[16.06.2026 22:16:48] Checking Existing File: 1u5t-14g386-cb.tar.gz
[16.06.2026 22:16:48] Copying: 1u5t-14g386-cb.tar.gz
[16.06.2026 22:16:48] Validating: 1u5t-14g386-cb.tar.gz
[16.06.2026 22:16:49] Copied: 1u5t-14g386-cb.tar.gz
[16.06.2026 22:16:49] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 22:16:49] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 22:16:49] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 22:16:49] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[16.06.2026 22:16:49] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 22:16:49] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 22:19:01] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 22:19:54] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[16.06.2026 22:19:54] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 22:19:54] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 22:20:50] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 22:21:12] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[16.06.2026 22:21:12] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 22:21:12] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 22:21:17] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 22:21:19] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[16.06.2026 22:21:19] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 22:21:19] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 22:22:30] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 22:22:59] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[16.06.2026 22:22:59] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 22:22:59] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 22:26:23] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 22:27:44] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[16.06.2026 22:27:44] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 22:27:44] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 22:28:29] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 22:28:46] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[16.06.2026 22:28:46] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 22:28:46] Copying: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 22:31:13] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 22:32:10] Copied: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[16.06.2026 22:32:10] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 22:32:10] Copying: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 22:33:45] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 22:34:22] Copied: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[16.06.2026 22:34:22] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 22:34:22] Copying: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 22:36:51] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 22:37:49] Copied: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[16.06.2026 22:37:49] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 22:37:49] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 22:41:21] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 22:42:45] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[16.06.2026 22:42:45] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 22:42:45] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 22:45:40] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 22:46:49] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[16.06.2026 22:46:49] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 22:46:49] Copying: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 22:50:30] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 22:51:54] Copied: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[16.06.2026 22:51:54] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 22:51:54] Copying: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 22:51:56] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 22:51:57] Copied: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[16.06.2026 22:51:57] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 22:51:57] Copying: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 22:55:21] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 22:56:40] Copied: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[16.06.2026 22:56:40] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 22:56:40] Copying: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 22:59:56] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 23:01:13] Copied: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[16.06.2026 23:01:13] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 23:01:13] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 23:03:40] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 23:04:38] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[16.06.2026 23:04:38] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 23:04:38] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 23:07:36] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 23:08:47] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[16.06.2026 23:08:47] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 23:08:47] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 23:08:47] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 23:08:47] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[16.06.2026 23:08:47] Generating reformat.lst
[16.06.2026 23:08:47] Generating autoinstall.lst
[16.06.2026 23:08:47] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
APIM firmware/calibration (still old, GB5T-era): App NU5T-14G381-AE (3.4.26057) · F188 Vehicle Mfr SW = GB5T-14G374-CB · F124 Calibration = GB5T-14G375-DA · F111 Core = HB5T-14G380-BA · F113 Delivery = HB5T-14G371-DAG · F110 = DS-GB5T-14G371-CB. The APIM still runs the original old (GB5T) calibration firmware — could this be why the cut-down nav config doesn’t persist across a cold boot, and would an APIM calibration-firmware update make it stick?
FORScan APIM AsBuilt confirms: Navigation enabled (7D0-01-02 = 02xx), all blocks match the working-3.0 values. APIM is on OLD firmware — no 7D0-08-xx / 7D0-09-xx lines present. Could the old calibration firmware be why the cut-down nav config doesn’t persist across a cold boot, and would a calibration-firmware update fix it?
Update / clarification:
  • The Syn3 Updater log attached above is from my initial full-EU Reformat attempt. What’s actually on the car is a cut-down EU package installed in Downgrade mode — correct creator log attached below.
  • Since posting: I reinstalled a fresh cut-down package (Downgrade mode). Nav works right after install but “Navigation Malfunction” returns after the next cold boot (hours off, no master reset). So it is not install corruption — it recurs every cold boot.
  • FORScan APIM AsBuilt confirms navigation is enabled (7D0-01-02 = 02xx) and all blocks match the working 3.0 state.
  • The APIM is on OLD firmware: FORScan shows no 7D0-08-xx / 7D0-09-xx asbuilt lines, and calibration is still GB5T-era (F188 = GB5T-14G374-CB, F124 = GB5T-14G375-DA).
  • Q: Could the old calibration firmware be why the cut-down nav config doesn’t persist across a cold boot? Would an APIM calibration-firmware update make it stick, or is this a known cut-down limitation on a Non-Nav-detected / retrofit unit (blank ECU serial F18C)?
Version: 3.4.26057
; CyanLabs Syn3Updater 2.14.2.0 Stable - downgrade Mode - Sync 3.4.26057 EU
FILES (13)
[18.06.2026 13:13:42] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: EU - 2026-06-18 - 1781777545
[18.06.2026 13:13:42] Install Mode: Auto-Detect (downgrade) Forced: False
[18.06.2026 13:13:42] MY20 Protection: Disabled / Not MY20
[18.06.2026 13:13:42] Formatting USB drive
[18.06.2026 13:13:42] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[18.06.2026 13:14:35] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[18.06.2026 13:14:37] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:37] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[18.06.2026 13:14:37] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[18.06.2026 13:14:37] Checking Existing File: 1u5t-14g386-cb.tar.gz
[18.06.2026 13:14:37] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[18.06.2026 13:14:37] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[18.06.2026 13:14:37] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:37] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[18.06.2026 13:14:47] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:47] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[18.06.2026 13:14:52] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:52] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[18.06.2026 13:14:53] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:53] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[18.06.2026 13:14:59] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:59] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[18.06.2026 13:14:59] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[18.06.2026 13:14:59] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[18.06.2026 13:15:13] Validated: 1U5T-14G421-BAM_1748461682000.TAR.GZ (Skipping Download)
[18.06.2026 13:15:13] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[18.06.2026 13:15:16] Validated: 1U5T-14G421-BBM_1748459859000.TAR.GZ (Skipping Download)
[18.06.2026 13:15:16] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[18.06.2026 13:15:26] Validated: 1U5T-14G421-BGM_1748462187000.TAR.GZ (Skipping Download)
[18.06.2026 13:15:26] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[18.06.2026 13:15:37] Validated: 4U5T-14G422-BDM_1748465073000.TAR.GZ (Skipping Download)
[18.06.2026 13:15:37] Preparing USB drive
[18.06.2026 13:15:39] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[18.06.2026 13:15:39] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[18.06.2026 13:16:13] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[18.06.2026 13:16:30] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[18.06.2026 13:16:30] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[18.06.2026 13:16:30] Copying: GB5T-14G386-SC_85041.tar.gz
[18.06.2026 13:16:30] Validating: GB5T-14G386-SC_85041.tar.gz
[18.06.2026 13:16:30] Copied: GB5T-14G386-SC_85041.tar.gz
[18.06.2026 13:16:30] Checking Existing File: 1u5t-14g386-cb.tar.gz
[18.06.2026 13:16:30] Copying: 1u5t-14g386-cb.tar.gz
[18.06.2026 13:16:30] Validating: 1u5t-14g386-cb.tar.gz
[18.06.2026 13:16:31] Copied: 1u5t-14g386-cb.tar.gz
[18.06.2026 13:16:31] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[18.06.2026 13:16:31] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[18.06.2026 13:16:31] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[18.06.2026 13:16:31] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[18.06.2026 13:16:31] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[18.06.2026 13:16:31] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[18.06.2026 13:18:03] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[18.06.2026 13:18:51] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[18.06.2026 13:18:51] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[18.06.2026 13:18:51] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[18.06.2026 13:19:31] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[18.06.2026 13:19:53] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[18.06.2026 13:19:53] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[18.06.2026 13:19:53] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[18.06.2026 13:19:56] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[18.06.2026 13:19:58] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[18.06.2026 13:19:58] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[18.06.2026 13:19:58] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[18.06.2026 13:20:49] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[18.06.2026 13:21:16] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[18.06.2026 13:21:16] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[18.06.2026 13:21:16] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[18.06.2026 13:21:16] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[18.06.2026 13:21:16] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[18.06.2026 13:21:16] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[18.06.2026 13:21:16] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[18.06.2026 13:23:42] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[18.06.2026 13:25:02] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[18.06.2026 13:25:02] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[18.06.2026 13:25:02] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[18.06.2026 13:25:34] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[18.06.2026 13:25:51] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[18.06.2026 13:25:51] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[18.06.2026 13:25:51] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[18.06.2026 13:27:56] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[18.06.2026 13:29:03] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[18.06.2026 13:29:03] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[18.06.2026 13:29:03] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[18.06.2026 13:31:11] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[18.06.2026 13:32:20] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[18.06.2026 13:32:20] Generating reformat.lst
[18.06.2026 13:32:20] Generating autoinstall.lst
[18.06.2026 13:32:20] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Your country code needs to match the NAV maps installed in the APIM settings/asbuilt. it must be set to one of these countries…
-BGx EU South: AL (Albania), BA (Bosnia and Herzegovina), HR (Croatia), MK (Macedonia), GR (Greece) HU (Hungary), IT (Italy), MT (Malta), ME (Montenegro), SM (San Marino), RS (Serbia), SL (Slovenia), TR (Turkey), VA (Vatican).
Thanks! Here’s my full APIM AsBuilt from FORScan:
7D0-01-01: 0A6A 0592 10F4
7D0-01-02: 02BE 4206 8264
7D0-02-01: 5455 0101 C045
7D0-02-02: 0B48 8000 00AE
7D0-02-03: 0000 DC
7D0-03-01: 0103 0000 00DF
7D0-04-01: 0100 1D00 241E
7D0-04-02: 0107 E5
7D0-05-01: 1AC2 1AA4 2BA2
7D0-05-02: D0AE
7D0-06-01: 805E
7D0-07-01: 0700 3300 0019
7D0-07-02: 0000 171C 0013
7D0-07-03: 0056 566D 00FA
7D0-07-04: 6A4C
Which line/byte is the country code, and what exact value should I write to set it to TR (Turkey) to match the BG / EU-South cut-down maps? I see 7D0-02-01 starts with 54 55 (“TU”) — should that become 54 52 (“TR”)? Want to confirm before writing. I have FORScan + USB OBD adapter ready.
Your country code is set to 5455, which is Turkey. Is this correct?
Yes — Turkey (TU / 5455) is correct. Turkish-market car + EU-South cut-down tile (includes Turkey), so that’s intended.
Since the country code already correctly matches the installed maps, what else would make nav work right after install but fail on every cold boot? Is this the known cut-down-maps behavior on a Non-Nav-detected / old-firmware (no 7D0-08/09) APIM, or another AsBuilt value to check?
Can you run the Interrogator Utility on the Syn3 Updater and post the results…
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2026-06-25" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0DXXWPCDGC27620</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AE</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432312d42414d000000000000000000315535542d3134473432312d42424d000000000000000000315535542d3134473432312d42474d000000000000000000355535542d3134473339312d415400000000000000000000345535542d3134473432322d42444d000000000000000000345535542d3134473432332d414300000000000000000000315535542d3134473635382d414800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>9bd51c23</d2p1:Response>
</d2p1:DID>
<d2p1:Response>471752a5</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0a6a05921002be420682</d2p1:Response>
</d2p1:DID>
<d2p1:Response>54550101c00b488000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0103000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001d00240107</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ac21aa42bd0</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>07003300000000171c000056566d006a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G380-BA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G371-DAG</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-DA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LV5900D6</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>80:30:dc:b3:57:a4</d2p1:Response>
</d2p1:DID>
<d2p1:Response>80:30:dc:b3:57:a5</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2026-06-25T19:40:57+00:00" RAM="1381662720" vmcuVersion="Vector_VMCU_05.02.02">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.2G" available="976K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.0G" available="15M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.4G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.6G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="983M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="72M" available="332K"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="8.7G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Hi @F150Chief, did you have a chance to take a look at the interrogator log?
