Reinstalling version 23188 Sync 3
I tried to reinstall version 23188 of my sync 3 leaving the current maps (apim my20 on ford smax 2016 my15, originally had sync 2) to clean it from the installed mods but after the stick is inserted the sync restarts normally
Install Type: Replica
Old SYNC Version: 3.4.23188
Syn3 Updater Version: V2.14.2.0
Version: 3.4.23188
Install Mode: Riconoscimento automatico (autoinstall)
My20 Protection Enabled: Riconoscimento automatico
Model: SanDisk Ultra USB 3.0 USB Device
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.23188 EU
Item2 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item3 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item4 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item5 = APPS - NU5T-14G381-AD_1689364279000.TAR.GZ
Open5 = SyncMyRide\NU5T-14G381-AD_1689364279000.TAR.GZ
FILES (5)
[14/10/2025 15:55:13] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Mantieni mappe esistenti
[14/10/2025 15:55:13] Install Mode: Riconoscimento automatico (autoinstall) Forced: False
[14/10/2025 15:55:13] MY20 Protection: Riconoscimento automatico
[14/10/2025 15:55:13] Formatting USB drive
[14/10/2025 15:55:13] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[14/10/2025 15:55:22] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 15:55:22] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 15:55:23] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 15:55:23] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 15:55:23] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 15:55:23] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:00:30] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:00:37] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:00:37] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:00:37] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:02:52] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:02:55] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:02:55] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:02:55] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:03:07] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:03:08] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:03:08] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:03:08] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:05:58] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:06:01] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:06:01] Preparing USB drive
[14/10/2025 16:06:01] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 16:06:01] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 16:06:01] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 16:06:01] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[14/10/2025 16:06:01] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:06:01] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:07:37] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:08:19] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[14/10/2025 16:08:19] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:08:19] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:09:16] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:09:38] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[14/10/2025 16:09:38] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:09:38] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:09:43] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:09:45] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[14/10/2025 16:09:45] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:09:45] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:10:56] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:11:19] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[14/10/2025 16:11:19] Generating Autoinstall.lst
[14/10/2025 16:11:19] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
The above is just a base reinstall.
If you’re referring to FMods items you have to use a their mod remover.
If you’re referring to ForScan changes, you would need to undo them with ForScan.
If you’re trying to wipe your BT pairing and other user settings that is done with a master reset.
We do not support jailbreak, but as the previous comment stated, you can go over their site to see how to un-JB the unit or to remove the mods at least.
I guess you could un-JB it via a reformat, which you can’t do since it’s MY20 hardware.
