I have an issue with Syn3 Updater app since first released. It occurs with Windows DPI settings different than 100%, resulting in the GUI being cut out.
I know it’s not a big deal since I can just use manual methor or change DPI every time I use the app, but it’s just annoying.
I’ve tried .exe compatibility settings with no success, I’m not sure if I’m missing something…
This is a known issue, won’t be fixed though, scaling on old style WinForms applications is just not something that is easily implemented, you need WPF for that and i don’t have much experience in that so won’t be migrating to it.
You can disable DPI settings per application by doing the following
