Removing Gracenotes and installing the smaller NA system voice file will give you 2.55GB of free space, enough to do the upgrade and local voice file. You should have enough room for the logo file for radio stations, but probably not Gracenotes. Follow the tutorial above, it will take you thru all of this.
I don’t understand something here. In the tutorial, it is only written and given how to reduce voice files to Na? There is talk of grecanotes … but nothing else. Unless the pendrive with freeing up space also removes grecanotes?
Linked in the tutorial: Removal of Gracenotes tutorial. This function is also available in the Syn3 Updater Tools section.
The Syn3 Updater can be used to create a Small Voice Package Replacement USB in the Tools section.
So I don’t have logs because there is not enough space? I will do as you say. First grecanotes, then files for later downgrade and only then installs the latest version. I’ll let you know how it went over the weekend. But I will have to install grecanotes files again, right?
In sum. The new gracanotes will be installed with the new update, right? Do I have to search for the correct file?
Remove Gracenotes, install the NA voice file, then see if you can install the latest software with the voice file and DAB file also.
Do NOT install Gracenotes at this point. Wait to see if there is enough storage after the above is done.
Managed to downgrade to 3.319052
now I’m ripping new updates
The update was successful. Now he wants to solve the dab issues …
Run the Interrogator Tool and post the results here.
-<p:OTAModuleSnapShot xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd” version=“2021-08-28” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0”>
<p:VIN>1FMCU0GD1HUBxxxxx</p:VIN>
-<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
-<p:Node specificationCategory=“GGDS” isFlashed=“false”>
-<d2p1:ECUAcronym name=“APIM”>
-<d2p1:Gateway gatewayType=“NONE”>
-<d2p1:DID responseLength=“24” didValue=“8033” didType=“Embedded Consumer Operating System Part Number” didFormat=“ASCII”>
d2p1:Response5U5T-14G381-ET</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“384” didValue=“8060” didType=“Embedded Consumer Applications Part Numbers 1” didFormat=“Packeted”>
d2p1:Response355535542d3134473339312d415000000000000000000000345535542d3134473432332d414300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“384” didValue=“8061” didType=“Embedded Consumer Applications Part Numbers 1” didFormat=“Packeted”>
</d2p1:DID>
-<d2p1:DID responseLength=“4” didValue=“D704” didType=“ECU Checksum 1” didFormat=“HEX”>
d2p1:Response2145e8b1</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“4” didValue=“D705” didType=“ECU Checksum 2” didFormat=“HEX”>
d2p1:Response28e49e8a</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE00” didType=“Direct Configuraation DID DE00”>
d2p1:Response2b28648b9608aa190000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE01” didType=“Direct Configuraation DID DE01”>
d2p1:Response555009044002405000400005</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE02” didType=“Direct Configuraation DID DE02”>
d2p1:Response0000040000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE03” didType=“Direct Configuraation DID DE03”>
d2p1:Response01000601080001</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE04” didType=“Direct Configuraation DID DE04”>
d2p1:Response18061810295f</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE05” didType=“Direct Configuraation DID DE05”>
d2p1:Response88</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue=“DE06” didType=“Direct Configuraation DID DE06”>
d2p1:Response1504330000000000fa000004306f0057</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“24” didValue=“F110” didType=“On-line Diagnostic Database Reference Number” didFormat=“ASCII”>
d2p1:ResponseDS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“24” didValue=“F111” didType=“ECU Core Assembly Number” didFormat=“ASCII”>
d2p1:ResponseHB5T-14G380-AA</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“24” didValue=“F113” didType=“ECU Delivery Assembly Number” didFormat=“ASCII”>
d2p1:ResponseHB5T-14G371-BAG</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“24” didValue=“F124” didType=“ECU Calibration Data #1 Number” didFormat=“ASCII”>
d2p1:ResponseGB5T-14G375-BA</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“16” didValue=“F141” didType=“Private Sub Node #1 Serial Number” didFormat=“ASCII”>
d2p1:ResponseWV7000DN</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“1” didValue=“F162” didType=“Software Download Specification Version” didFormat=“State Encoded”>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“1” didValue=“F163” didType=“Diagnostic Specification Version” didFormat=“State Encoded”>
</d2p1:DID>
-<d2p1:DID responseLength=“24” didValue=“F188” didType=“Vehicle Manufacturer ECU Software Number” didFormat=“ASCII”>
d2p1:ResponseGB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“16” didValue=“F18C” didType=“ECU Serial Number” didFormat=“ASCII”>
</d2p1:DID>
-<d2p1:DID responseLength=“6” didValue=“F1D0” didType=“ECU MAC Address 1” didFormat=“HEX”>
d2p1:Responseb0:d5:cc:33:6a:10</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength=“6” didValue=“F1D1” didType=“ECU MAC Address 2” didFormat=“HEX”>
d2p1:Responseb0:d5:cc:33:6a:11</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:ODLNetwork d2p1:Pins=“6,14” d2p1:DLCName=“SAE J1962” d2p1:NetworkProtocol=“CAN” d2p1:NetworkName=“HS-CAN” d2p1:NetworkDataRate=“500”/>
-<d2p1:AdditionalAttributes vmcuVersion=“Vector_VMCU_02.02.20” RAM=“1498431488” logGeneratedDateTime=“2021-08-28T19:27:27+00:00”>
<d2p1:PartitionHealth available=“8.4M” total=“1.9G” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“21M” total=“1003M” type=“/fs/Nuance/grace”/>
<d2p1:PartitionHealth available=“1.0G” total=“1.2G” type=“/fs/rwdata/”/>
<d2p1:PartitionHealth available=“35M” total=“35M” type=“/fs/rwdata/quip/”/>
<d2p1:PartitionHealth available=“90M” total=“90M” type=“/fs/rwdata/quip/”/>
<d2p1:PartitionHealth available=“132M” total=“1.4G” type=“/fs/mp/”/>
<d2p1:PartitionHealth available=“7.3M” total=“3.0G” type=“/fs/images/”/>
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
You don’t have the storage space (memory) available to install the DAB file. It’s either Gracenotes or DAB.
<d2p1:PartitionHealth available=“8.4M” total=“1.9G” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“21M” total=“1003M” type="/fs/Nuance/grace"/>
<d2p1:PartitionHealth available=“1.0G” total=“1.2G” type="/fs/rwdata/"/>
<d2p1:PartitionHealth available=“35M” total=“35M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“90M” total=“90M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“132M” total=“1.4G” type="/fs/mp/"/>
<d2p1:PartitionHealth available=“7.3M” total=“3.0G” type="/fs/images/"/>
If you could use another voice file that does not include Polish, you could gain the memory needed for the DAB file with Gracenotes. Unfortunately, the large EU voice file is the only one with Polish language.
so now what? to delete grecanotes? and download DAB?
I have a car from the USA … a file that contains Polish can be reduced as well?
Delete Gracenotes, install the DAB file.
None of the Gracenotes files include Polish according to the notes on FFClub. When you are using Gracenotes now, what language appears? Which file is installed? (-AC?) It might be possible to use a smaller GN file. See this tutorial for a list of languages and files.
I noticed your region is set to Ukraine (5550) rather than Poland (504C).
There is only the one file version with Polish language, which you have installed.
DAb file is 60MB. If I think correctly, can you edit the language file in such a way as to make it smaller?
Yes you are right. I separately downloaded the Polish language file and added it to the update. After removing grecanotes and installing a smaller voice file and after downgrade. I still had Polish in the navigation menu. I will do everything again from the beginning, only without the Polish language file. And how to change from Ukraine to Polish? Through the forscan?
Yes.
7D0-02-01 **** xxxx xxxx
Set to 504C.
You don’t need to start over, Just load the new voice file you want, then install the DAB file, then install Gracenotes file. But starting over with the new files will clean out the APIM, so this might be good.
