Sound Setting or Fade/Balance Not saving. 2018 F150
I have just installed and updated a donor 8inch/NAV from a 2016 f150 lariat super crew cab vin # 1FTEW1EG5GFC53564. I was able to get the APIM and ACM from the same vehicle. Had to program the ACM to Asbuilt 2018 for the volume knob/steering to work prior to updating. APIM still asbuilt to the donor vehicle since it won’t allow me to have NAV. After doing the 3.423188 updates with Maps it would not allow me to properly configure Fader/Balance or Trebel/Mid/Bass. I have tried solutions discussed in this forum but nothing seems to work yet. I have also reloaded the asbuilt from donor vehicle for the APIM and ACM from asbuilt from my vehicle but still the same issue. I have done the Master Reset several times with no luck.
Old SYNC Version: 3.019205
New SYNC Version: 3.423188
Only error is unsupported hub which I would be replacing soon. Got scammed/swapped out the right part number.
Syn3 Updater Version: Lasted as of yesterday.
Trying to work on this
You don’t want the AB from the donor, you want it from yours as the 2016 was Sync3 native.
The problem is that the donor config is wrong for what is in your F150.
If you didn’t have NAV originally you would change 7D0-01-02 from x0xx xxxx xxxx to x2xx xxxx xxxx after loading your vehicle AB into the APIM to enable NAV.
