Cheers for that, I will give it a go, the master reset just hangs so far when selected, even after multiple soft resets, maybe unplugging the battery will help.
I installed the 3.4.22251 version sometime last year and it successfully installed, has worked great until the last couple months and now upon every start up I go through several prompts for updates and apple CarPlay like it’s not saving my settings as well as 1 out of every 4 or 5 startups it’s just a black screen that I have to do a soft reset to get even the prompts to come up. I’m hoping that an upgrade to the latest 3.4 version will fix this? I only have access to a Mac. I understand I have to downgrade to an older version before upgrading to the latest version correct? Any advice would be great to fix this please.
Download an Interrogator log package and run it, your data partitions are probably full. If you decide to upgrade to 23188 MAKE SURE you CORRECTLY answer the MY20 questions.
I believe there’s an Windows emulator that you can download, i have seen it mentioned and you’ll have to have a read up on it because it tries to be helpful and de-archives the files which is unwanted.
