Syn3 bricked
Hi everyone, I tried to update the Sync 3 calibration files with Forscan, but the writing upload stopped and now the system is bricked.
Thank you and best regards.
Andrea Puglia
Old SYNC Version: 3.4.21098
New SYNC Version: 3.4.23088
Version: 3.4.21098
Install Mode: Riconoscimento automatico (autoinstall)
My20 Protection Enabled: Riconoscimento automatico
Model: SanDisk Ultra USB 3.0 USB Device
Size:
; CyanLabs Syn3Updater 2.13.0.0 Stable - Autoinstall Mode - RWData Cleaner
FILES (3)
GB5T-14G386-AD_1606255780000.TAR.GZ (46,1KB)
Sync_NX2C015P_WF0JXXGAHJJY03060.xml (11,2KB)
[27/12/2024 15:38:14] Selected Region:  - Release: RWData Cleaner - Map Version:
[27/12/2024 15:38:14] Install Mode: Riconoscimento automatico (autoinstall) Forced: False
[27/12/2024 15:38:14] MY20 Protection: Riconoscimento automatico
[27/12/2024 15:38:14] Formatting USB drive
[27/12/2024 15:38:14] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[27/12/2024 15:38:21] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:21] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Preparing USB drive
[27/12/2024 15:38:22] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[27/12/2024 15:38:22] Generating Autoinstall.lst
[27/12/2024 15:38:22] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
for scan config…
Interfaccia:
Porta: COM4, 500000 bps
Tipo: Standard COM
Adattatore: ELM327 v1.5
Ritardo min.: 11 ms ( Buono)
Errori: Nessuno
Veicolo:
Modello: Ford Fiesta
Motore: Duratorq Turbo Diesel Common Rail Injection
Cilindrata: 1.5L
Anno: 2018
mese: 02
Generazione: 2017 MY
Carburante: Diesel
Trasmissione: Manuale
SYNC version: SYNC 3
VIN: WF0JXXGAHJJY03060
PCM - Modulo gestione motore
Part number: HA6A-12A650-RB
Calibration level: HA6A-12A650-SM (latest known: HA6A-12A650-SR)
Strategia : HA6A-14C204-SM
Hardware type: HA6A-12B684-MA
OBDII - On Board Diagnostic II
APIM - Modulo interfaccia protocollo accessori
Part number: JK2T-14G371-FCC
Calibration level: JK2T-14G371-FDH
Strategia : GB5T-14G374-DG
Calibrazione: GB5T-14G375-FD
PAM - Modulo ausilio parcheggio
Part number: HU5T-15K866-AE
Calibration level: HU5T-15K866-AE (latest known: HU5T-15K866-AG)
Strategia : HU5T-14C090-AE
BdyCM - Modulo di comando carrozzeria
Part number: HU5T-14B476-BCN
Calibration level: HU5T-14B476-BCR (latest known: HU5T-14B476-BCS)
Strategia : HU5T-14C184-ACR
You can’t update Sync3 files with ForScan.
All you can do is update the APIM firmware (which requires 2.4.x) and this isn’t part of Sync3, or you can modify the APIM config to change the functionality of Sync3.
Hi, I blocked the system by updating the apim.
See if you can recover the APIM using this tutorial…
